09-26-2009, 13:08 | #1 (permalink) |
Banned Join Date: Mar 2008 Location: pakistan city jhelum
Member: 720284 Status: Offline Thanks Meter: 13 | how to flash lg on infiniti box |
09-26-2009, 13:41 | #2 (permalink) | |
No Life Poster Join Date: Sep 2009 Location: My Lappy Age: 37
Member: 1115989 Status: Offline Sonork: 9905677786 Thanks Meter: 3,202 | how to flash Quote:
Step2=select model Step3=Run after do this automatically open one window(pana) step4= select device step5=check com port step6=Flash a.load firmware, b.load language pack final step=click on write. thanks!!!!!! | |
The Following 2 Users Say Thank You to sheik9905677786 For This Useful Post: |
09-26-2009, 14:15 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
09-27-2009, 09:24 | #4 (permalink) |
Member: 720284 Status: Offline Thanks Meter: 13 | But there are many function on flash page BUT THERE ARE MANY FUNCTION ON FLASH PAGE FIRST LOADFIRMWARE SECOND LANGUAGE PACK THIRD FFS FOUR EEPROM and sport side have only bin file.please tell how to recognize the firmfare and language file |
09-27-2009, 09:57 | #5 (permalink) |
Freak Poster Join Date: Aug 2004 Location: Germany
Member: 76018 Status: Offline Thanks Meter: 59 | you can find the Files for your Modell in Support... when you see whcih Files you need to flash. If you use a Box you should have a little knowledge about Computers/Mobiles |
09-27-2009, 10:35 | #6 (permalink) |
Member: 720284 Status: Offline Thanks Meter: 13 | I know sport side but i do not know who is firmware language ffs and eeprom file please tel how to recognize these file pleassssssssssssssssssssssssssssssssssssssssssssss sss |
09-27-2009, 11:15 | #7 (permalink) | |
Member: 1115989 Status: Offline Sonork: 9905677786 Thanks Meter: 3,202 | model Quote:
firstly give me full question that about which model you desire to flash? because there lots of model. and there is also lots of extension of file. thanks!! | |
09-28-2009, 07:50 | #10 (permalink) |
Member: 720284 Status: Offline Thanks Meter: 13 | yes brother i am a new user tel me about the kg270 flash file.brother tell me properle how to recognize the file.for example as a nokia three file mcu ppm cnt mcu big file ppm ae and cnt nai ae please solved my problems |
09-28-2009, 09:08 | #12 (permalink) | |
Member: 1115989 Status: Offline Sonork: 9905677786 Thanks Meter: 3,202 | flash file Quote:
fIrstly use firmware =KG270P16-07-V10f-XXX-XX-JUN-14-2007+0_firmware[1].B1M secondly use language file=KG270P16-07-V10f-XXX-XX-JUN-14-2007+0_LP_En_Ru_Ua_Kz_Lt_Lv_Ee[1].B1P after it click on write option thanks!!! | |
09-28-2009, 09:33 | #13 (permalink) |
Member: 720284 Status: Offline Thanks Meter: 13 | Thanks .but tel me firmware file have end of the word bim and language bip.i am right.again thanks thanks.if you dont mind you tel me own yahoo email adrees because next time i take a help with you |
09-28-2009, 10:01 | #14 (permalink) | |
Member: 1115989 Status: Offline Sonork: 9905677786 Thanks Meter: 3,202 | extension Quote:
no brother firmware = firmware (.bin) language = LP_En_Ru_Ua_Kz_Lt_Lv_Ee (.lp) by the way here is my id= [email protected] thanks!!!!!!! | |
09-29-2009, 10:30 | #15 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | KG270P16-AFR-V10d-000-00-JUN-13-2007_firmware.B1M.bin = main firmware KG270P16-AFR-V10d-000-00-JUN-13-2007_LP.B1P.bin = language pack (LP) KG270P16-AFR-V10d-000-00-JUN-13-2007_file_system.B1S.bin = phone content (default logo etc) |
How to flash lg kp110 in infinity box | shivashakthi | Infinity-Box | 3 | 12-02-2013 11:39 |
how to flash lg kg300 with infinity box | shahid555 | LG Hardware Repair | 2 | 10-31-2008 17:43 |
How to flash c261 with infinity box | Hadiir | Motorola Hardware Repair | 0 | 10-18-2008 18:41 |
Help on how to flash LG u8360 | djouaka | LG | 6 | 01-25-2008 01:20 |
Help on how to flash LG u8360 | djouaka | HWK | 6 | 01-24-2008 23:36 |
