Old 12-10-2016, 14:29   #1 (permalink)
.::Mustafa::.'s Avatar
Member: 1857951
Sonork: 100.1638512
Thanks Meter: 202
Infinity Team Help Me Please..
I have Many Bin Files but i want to make In scatter files .i know MTK Droid Tool Convert the bin file to scatter file but Need to connect the mobile In USB Dub Mode.Now i have a many models bin file No mobile in hand.
i hop Team and My friends Understand My Question.
Thanks in advance
Regards
.::Mustafa::.
Old 12-10-2016, 15:05   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,040
Hello,
Infinity-Box CM/CM2 already supports .bin file format, so there shouldn't be any problem in using it.
About conversion it's not possible for now.
Br.
Infinity Box Support Team.
The Following 2 Users Say Thank You to PASSIONATE_BOYS For This Useful Post:
Old 12-11-2016, 06:59   #3 (permalink)
Member: 1857951
Sonork: 100.1638512
Thanks Meter: 202
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Br.
sir thanks to reply but i face problem in bin file i read bin file with other box just like Miracle box and Volcano box when i load the bin file with cm2 show u load the bad or unsupported file But other box Flash done with same file .In That resin i convert bin file to Scatter file .I can not Flash the phone with Bin file with Cm2 Dongle.
Old 12-11-2016, 10:02   #4 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,040
Because it's Nand, which is not supported yet!
Br.
Old 12-11-2016, 10:22   #5 (permalink)
Yusuf Lawal's Avatar
Member: 1677653
Thanks Meter: 2,026
Yes, is good for someone to understand this very well
Old 12-11-2016, 10:24   #6 (permalink)
Member: 1857951
Sonork: 100.1638512
Thanks Meter: 202
Nand is not issue face with multi chips
Old 12-11-2016, 11:41   #7 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,040
Could you explain more about multi chips?
Also if possible with phone details and logs.
Br.
Old 12-11-2016, 13:03   #8 (permalink)
Member: 1857951
Sonork: 100.1638512
Thanks Meter: 202
Br.
Samsung G530H(GALAXY Grand Prime) MT6572
Wait for phone...
Phone found! [ 11 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : 009800BC009000660076001500010000
eMMC Flash : NOT INSTALLED
Initialize Memory ...
DAgent sent , init HW now
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0097 , NAND_UNKNOWN
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 1000/0040/01/NIM_Px-1
DEV RID : 0xC3555188BF151143E96970694DE6461C
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Please add bin to file converter in Great Tool CM2
Regards
.::Mustafa::.
Old 12-11-2016, 13:44   #9 (permalink)
MDxavi's Avatar
Member: 1882912
Sonork: 100.1677703
Thanks Meter: 242
Wait for phone...
Phone found! [ 11 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Regards
.::Mustafa::.
it's Nand chip
SOC VERIFY : C1
Boot Ok!
Old 12-11-2016, 14:25   #10 (permalink)
Member: 1155715
Sonork: ahmad.derakhshan61
Thanks Meter: 16
its nand chip bro
you should found flash file for your phone.search net
Page generated in 0.32016 seconds with 7 queries
