02-09-2011, 02:50
#1 (permalink)
Member: 665989
Sonork: 100.1597348 Thanks Meter: 552 | Gfive t33+ not booting in chinese miracle Gfive t33+(dead) not booting in chinese miracle
Read general info failed.....
This is detailed info Quote:
COM35 [VCP0] selected
module v3.26
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: read/check information
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:3203:0005
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98000300000001:18A59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset assigned: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
detecting ffs/eeprom structure pass 1...
ffs/eeprom: can't detect record name location
error: ffs/eeprom detection failed: element #1
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
detecting firmware version...
done
warning: can not detect firmware version
if software freez: make "Find firmware version (slow process)" unchecked and repeat operation.
detecting firmware build...
done
detecting product-id...
done
detecting languages...
language parameters detected
detected languages: En Ru Fr Es Id Tr Hi Urdu Farsi Pt Ar
Finished, time used: 1 min 46 sec
Remove/Install battery now !
