Infinity Team help me urgent I unlocked T-Mobile Zest. after unlock successfully power on the phone and error come on the screen (nvram-sec.c, 657, 241: ) :mad::mad: I flashed it with it's backup but same:mad::mad:. here is the flash detail.Please help me urgent how to solve it. Thanks COM3 [VCP0] selected module v3.73 Device: T-Mobile-Zest Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active "format ffs" active write: Firmware T-Mobile-Zest_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P10 9A17V1_0_1B04__ffs_20110210-122709.B0E.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:64AD:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98009600000000:2AEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P109A17V 1_0_1B04.BIN project-id: TMO_UK_P109A17V1.0.1B04, 00000000 code offset: 00000000 ffs offset/size [02]: 00600000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00600000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: T-Mobile-Zest_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P10 9A17V1_0_1B04__ffs... file saved: C:\Documents and Settings\My Phone\Desktop\T-Mobile-Zest_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P10 9A17V1_0_1B04__ffs_20110210-123803.B0E.bin Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... firmware patch (general #0)... not required firmware patch (sp-lock #1)... not required firmware patch (sp-lock #2)... not required Special operation Done ====> Write ... Area: Firmware flash: 98009600000000:2AEA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... ffs formatting... flash: 98009600000000:2AEA0000000000 Finalization Done Finished, time used: 6 min 31 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
1. flash phone with firmware file, not with eeprom file 2. unlock phone once again, but DO NOT change unlock method in software, use default unlock method for this model "smart fast" |
COM3 [VCP0] selected module v3.73 Device: T-Mobile-Zest Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware T-Mobile-Zest_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P10 9A17V1_0_1B04_2010-07-12_En.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:64AD:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98009600000000:2AEA0000000000 flash: AMD/Fujitsu std [T 0008x002000 007Fx010000] 8Mb otp offset: 007F0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P109A17V 1_0_1B04.BIN project-id: TMO_UK_P109A17V1.0.1B04, 00000000 code offset: 00000000 ffs offset/size [02]: 00600000/00200000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00600000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: T-Mobile-Zest_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P10 9A17V1_0_1B04__ffs... file saved: C:\Program Files\InfinityBox\MModule\T-Mobile-Zest_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.TMO_UK_P10 9A17V1_0_1B04__ffs_20110210-143342.B0E.bin Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Area: Firmware flash: 98009600000000:2AEA0000000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 5 min 36 sec Remove/Install battery now ! |
I have solved problem with both files....firmware and eprom files. and also unlocked with the method of smart fast. Thanks for helping me. COM3 [VCP0] selected module v3.73 Action: "sp-unlock" unlock method: smart fast Model: T-Mobile-Zest Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:64AD:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: TMO_UK_P109A17V1.0.1B04 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 35926403198276 connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 13 sec Remove/Install battery now ! |
