01-18-2011, 17:37 | #1 (permalink) |
No Life Poster Join Date: Oct 2007
Member: 605126 Status: Offline Sonork: 100.1617907 Thanks Meter: 297 | Huawei G6620 need unlock i try with g6610 but get this error COM6 [VCP0] selected module v3.72 Device: Huawei-G6610 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6253:8A02:8A00]... CPU: MT6253 chip: 0000:0000:000F status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 18 sec Remove/Install battery now ! and u7530 COM6 [VCP0] selected module v3.72 Action: "sp-unlock" unlock method: smart fast Model: Huawei-U7530 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 chip: 0000:0000:000F status: FF Connecting at 19200, wait... warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware 80 byte(s) read |
The Following User Says Thank You to louisgsm For This Useful Post: |
01-18-2011, 17:51 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, run ChineseMiracle software, select NAND model and read full flash image. Please, send full flash backup file (or link) to [email protected] |
01-21-2011, 19:33 | #5 (permalink) |
Member: 605126 Status: Offline Sonork: 100.1617907 Thanks Meter: 297 | here is the full flash also send to ur support link SJ_S0A_HW_VODAFONE_PCB01_GPRS_MT6253_S00.G6620SS_C 210_M40_04_05.BIN_FLNTY6801111190KC__firmware_2011 0119-110338.B0M.bin - 4shared.com - online file sharing and storage - download COM6 [VCP0] selected module v3.25 Device: Autodetect 6228-6253 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A02:8A00 status: FF bbchip bl ver: FE NOR flash id[00AD]: 0098:005F00000000 [TOSHIBA] TC58FYM8T8D chip size: 32Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: G6620SS_C210_M40_04_05 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NOR)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NOR)... error: unexpected answer: startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: SJ_S0A_HW_VODAFONE_PCB01_GPRS_MT6253_S00.G6620SS_C 210_M40_04_05.BIN_FLNTY6801111190KC project-id: G6620SS_C210_M40_04_05, 8209A63A code offset: 00000000 ffs offset/size [02]: 01600000/009E0000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done area size: 22Mb number of areas/bytes to read: 1:01600000 reading (HW_STORAGE_NOR)... file saved: C:\Documents and Settings\louisgsm\Desktop\SJ_S0A_HW_VODAFONE_PCB01 _GPRS_MT6253_S00.G6620SS_C210_M40_04_05.BIN_FLNTY6 801111190KC__firmware_20110119-110338.B0M.bin Disconnect... done Finished, time used: 11 min 35 sec Remove/Install battery now ! |
The Following 4 Users Say Thank You to louisgsm For This Useful Post: |
02-27-2011, 05:58 | #10 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,925 | Hello, Please, try to use this new software: http://www.infinity-box.com/download...dule_v3.77.rar 1. make full flash backup for emergency case ! 2. try to unlock phone with "read unlock codes" method only, DO not try other unlock methods ! Please, post here operation log. Waiting for your results. |
03-03-2011, 01:04 | #11 (permalink) |
Freak Poster Join Date: Mar 2011
Member: 1527517 Status: Offline Sonork: 100.1607096 Thanks Meter: 9 | g6620 unlock ok g6620 unlock ok COM6 [VCP7] selected module v3.77 Action: read unlock codes unlock method: read codes Model: Huawei-G6620 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: G6620SS.C210.M40.04.05 Version: CKT53_12832_09B_HW ==================== New firmware found (v.3.77, database date: 01.03.2011): G6620SS.C210.M40.04.05 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 116 byte(s) read imei: 3519480xxxxxxx connection Ok 217 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 205 byte(s) read reading data... 220 byte(s) read lock[1] code: + 35282734 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 1439 min 1 sec Remove/Install battery now ! thanks infinity taim |
The Following User Says Thank You to askjour For This Useful Post: |
03-04-2011, 14:02 | #12 (permalink) |
Junior Member Join Date: Aug 2003
Member: 37538 Status: Offline Thanks Meter: 6 | Hi, Here you have a flash file not supported for infinity box: http://rapidshare.com/files/45090561...6801111190KC__ Thanks!! PK2 |
The Following User Says Thank You to PK2 For This Useful Post: |
03-07-2011, 18:31 | #13 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Nador-Morocco Age: 38
Member: 694713 Status: Offline Thanks Meter: 92 | OM9 [VCP0] selected module v3.77 Action: read unlock codes unlock method: read codes Model: Huawei-G6620 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6253:8A02:8A00]... CPU: MT6253 chip: 0000:0000:000F status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6253,E02 Date: 2000.00.00 Version: 1.0 Version: G6620SS.C210.M40.04.05 Version: CKT53_12832_09B_HW ==================== New firmware found (v.3.77, database date: 03.03.2011): G6620SS.C210.M40.04.05 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 116 byte(s) read imei: 35194804277244 connection Ok 217 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 205 byte(s) read reading data... 220 byte(s) read lock[1] code: + 41613922 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 17 sec Remove/Install battery now ! |
The Following User Says Thank You to OpssPhone For This Useful Post: |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
