Infinity team help me . Viettel v6202 unlock done but phone dead ! COM10 [VCP2] selected module v3.78 Device: Viettel-V6202 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:50AA:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.VE-VN-VT9S-P109A17MV1_0_4B01.BIN project-id: VE-VN-VT9S-P109A17MV1.0.4B01, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00880000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Viettel-V6202_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.VE-VN-VT9S-P109A17MV1_0_4B01__ffs... file saved: C:\InfinityBox\MModule\Viettel-V6202_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.VE-VN-VT9S-P109A17MV1_0_4B01__ffs_20110304-164245.B0E.bin flash: EC257E25082501:2AEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... ........................ required data found flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: area 1 (pass 1) ........................................ area 1 patch applied Ok detecting parameters to apply patch area 2... .................. required data found flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: area 2 (pass 1) .............................................. area 2 patch applied Ok detecting parameters to apply patch area 3... .................. required data found flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: area 3 (pass 1) .............................................. area 3 patch applied Ok Special operation Done ====> Write ... flash: EC257E25082501:2AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 7 min 32 sec Remove/Install battery now ! UNlock oke but phone dead ! |
Hi, Flash phone with this firmware from support area: Viettel-V6202_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.VE-VN-VT9S-P109A17MV1_0_4B01_2010-11-09_En_Vn.B0M.bin and phone will be alive for sure. Then try to make "read unlock codes" operation. What is the results ? |
I had flashed file on support with this firmware from support area: Viettel-V6202_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.VE-VN-VT9S- Then try unlock not ok |
