Old 03-04-2011, 10:51   #1 (permalink)
Member: 754345
Thanks Meter: 32
Infinity team help me . Viettel v6202 unlock done but phone dead !
COM10 [VCP2] selected
module v3.78
Device: Viettel-V6202
Checking data, wait...
Action: "sp-unlock"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:50AA:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC257E25082501:2AEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (07)
TCL-ID is absent
rom info detection finished
rom info ver: 07
sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.VE-VN-VT9S-P109A17MV1_0_4B01.BIN
project-id: VE-VN-VT9S-P109A17MV1.0.4B01, 00000000
code offset: 00000000
ffs offset/size [02]: 00880000/00780000
TCL-ID is absent
ffs/eeprom address assigned: 00880000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: Viettel-V6202_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.VE-VN-VT9S-P109A17MV1_0_4B01__ffs...
file saved: C:\InfinityBox\MModule\Viettel-V6202_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.VE-VN-VT9S-P109A17MV1_0_4B01__ffs_20110304-164245.B0E.bin
Backup required data Done
====> Patch required data ...
detection procedure, wait...
detection procedure completed
error: phone is not locked or unknown eeprom
Patch required data Done
====> Special operation ...
detecting parameters to apply patch area 1...
required data found
Write: area 1 (pass 1)
area 1 patch applied Ok
detecting parameters to apply patch area 2...
required data found
Write: area 2 (pass 1)
area 2 patch applied Ok
detecting parameters to apply patch area 3...
required data found
Write: area 3 (pass 1)
area 3 patch applied Ok
Special operation Done
====> Write ...
Write: ffs
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 7 min 32 sec
Remove/Install battery now !
UNlock oke but phone dead !
Old 03-04-2011, 23:40   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hi,
Flash phone with this firmware from support area: Viettel-V6202_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.VE-VN-VT9S-P109A17MV1_0_4B01_2010-11-09_En_Vn.B0M.bin and phone will be alive for sure.
Then try to make "read unlock codes" operation. What is the results ?
Old 03-05-2011, 04:17   #3 (permalink)
Member: 733209
Sonork: 1001620525
Thanks Meter: 426
I had flashed file on support with this firmware from support area: Viettel-V6202_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.VE-VN-VT9S-
Then try unlock not ok
The Following User Says Thank You to hung phong For This Useful Post:
Old 03-07-2011, 17:44   #4 (permalink)
Member: 130995
V6202 unlock not ok
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-25-2009 17:29
Page generated in 0.26630 seconds with 8 queries
