04-10-2008, 06:40 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Georgia GE
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | Infinity Team i want help. after format mobile dead cable type: 1x18 (L18A) platform: MT6205, MT6217-MT6228 searching adapter at COM6... adapter found, version: 2000 pins: 18, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6226 result: Rx:7 Tx:9 time required: 51 sec Power On ! COM6 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:0876:4872 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.6482588B.[E551_C4QF8_E551_GPRS_MT6226_S01.01_0.BIN_6ABFFCDD].rpl identification#1 detection finished device-id: 6482588B identification#1 protocol ver: 04 ver. sw1: E551_C4QF8_E551_GPRS_MT6226_S01.01_0.BIN ver. sw2: E551_C4QF8.01.0, 22034095 ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area i press YES Do you want to use standard ffs address: 00800000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00800000 ffs chip: 00 eeprom/ffs area: 00000000:00800000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[E551_C4QF8_E551_GPRS_MT6226_S01.01_0.BIN]]... file saved: C:\Documents and Settings\Mr Eko\Desktop\New Folder\backup_eeprom[E551_C4QF8_E551_GPRS_MT6226_S01.01_0.BIN]_20080410-092343.B0E.bin flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _6482588B_E551_C4QF8_E551_GPRS_MT6226_S01.01_0.BIN _6ABFFCDD_20080410-092448.B0X.bin Finished, time used: 439 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
04-10-2008, 09:08 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: France Age: 48
Member: 165812 Status: Offline Sonork: 100:1627635 Thanks Meter: 4,267 | it is so easy 1- in case u read backup flash from the phone u can write it back 2- if u did not do first step then here u get : E551_C4QF8_E551_GPRS_MT6226_S01.01_0.BIN get it from support and flash it to the phone . 3- try to do complete format and keep power button for more than 1 min |
04-10-2008, 11:18 | #3 (permalink) |
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | problem solved after this procedure: write flash: E551_C4QF8_E551_GPRS_MT6226_S01.01_0.BIN downloaded from support area write eep/ffs backup: backup_eeprom[E551_C4QF8_E551_GPRS_MT6226_S01.01_0.BIN]_20080410-092343.B0E size: 4.9mb and safe format if compete format then mobile again dead, i select safe format and problem solved mobile turned on |
04-10-2008, 14:41 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! you could also do this way: when you phone went dea after Format FFS complete- you had to restore your backup C:\Documents and Settings\Mr Eko\Desktop\New Folder\backup_eeprom[E551_C4QF8_E551_GPRS_MT6226_S01.01_0.BIN]_20080410-092343.B0E.bin and then make format FFS in safe mode |
SL45 need help after format dead | jakoy | DreamBox | 1 | 03-05-2009 16:35 |
Infinity Team I want help. After format no Network | IkaMazini | Infinity-Box | 20 | 06-29-2008 05:24 |
A5 after format ffs dead plssss help.......... | rk19801 | Infinity-Box | 5 | 04-13-2008 21:48 |
need help n82 after format phone dead | bilousoft | Chinese Cocktail | 1 | 12-27-2007 10:44 |
HI INFINITY TEAM-We want moto v3 and v3i flashing and unlocking | PASSIONATE_BOYS | Infinity-Box | 2 | 09-16-2007 11:52 |
