12-09-2015, 15:14 | #1 (permalink) |
No Life Poster Join Date: May 2013 Location: UFI-BOX+EASYJTAG BOX Age: 34
Member: 1934602 Status: Offline Sonork: 100.1649323 Thanks Meter: 482 | Infinity Team Jaidy Help Me........ Read Problem Nand Cpu,Im New User cm2 .................................................. ................... Operation : Check / Read Info [ v1.38 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/00/NIM_Px-1 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done Erased phone or unsupported FlashIc? You can change settings : Settings -> Other -> NAND init Mode Done! Elapsed: 00:00:10 Reconnect Power/Cable! Quick Reaplay Team ........................ |
12-09-2015, 15:23 | #2 (permalink) |
Banned Join Date: Jul 2011 Age: 32
Member: 1609044 Status: Offline Thanks Meter: 892 | info read not done Erased phone or unsupported FlashIc? You can change settings : Settings -> Other -> NAND init Mode cheek this what your software say do that |
The Following 2 Users Say Thank You to gsm_mithun For This Useful Post: |
12-09-2015, 15:31 | #4 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: Ethiopia
Member: 449991 Status: Offline Thanks Meter: 933 | try other nand init mode Quote:
The Following 3 Users Say Thank You to dereje For This Useful Post: |
