02-10-2009, 06:34 | #1 (permalink) |
Freak Poster Join Date: Jul 2004
Member: 73455 Status: Offline Thanks Meter: 23 | LG-KG245 unlocked with infinity logs COM25 [VCP0] selected module v1.36 Device: LG-KG245 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 0000527A Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 359103001551331 current otp imei: 359103001551331 file saved: C:\Program Files\InfinityBox\LGA\eeprom_359103001551331_LG-KG245_20090210-120336.B1E.bin .......... version: 505-03V10a61KG245P64FL Check flash Done Check space ... current eeprom imei: 359103001551331 .................................................. .............. finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 79 sec Remove/Install battery now ! |
The Following User Says Thank You to topnoyze For This Useful Post: |
LG KG245 unlock successfully by infinity | kmaxmax | Infinity-Box | 1 | 05-13-2009 06:52 |
Lg Kg245 Kiled by Infinity-Box Revived by | KhalIman | Infinity-Box | 24 | 01-09-2009 15:50 |
Lg Kg245 Unlock | inat | FuriousGold | 22 | 05-17-2007 22:16 |
Lg Kg245 Unlock Any Solution Yet ? | simclub1 | HWK | 1 | 10-08-2006 15:16 |
lg KG245 UNLOCK | alloujdi | LG | 1 | 06-25-2006 05:33 |
