Old 02-06-2009, 11:02   #1 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
Infinity-team look this problem in kg280
hi
i have a kg280 when i put fail SIM CARD (( registration failed)) ok but when i put the ok SIM in phone then say INSERT SIM AND yes only work AIRTEL SIM (1800)
COM7 [VCP0] selected
module v1.36
Device: LG-KG280
Checking data, wait...
Action: flash write
Skip: Firmware (code)
Skip: File system
Write: Alchemy data
Skip: Eeprom
"smart write" active
"keep calibration" active
Boot ...
Connecting, wait...
Release Power button now !
flash: 01227E223C2200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb
Boot Done
Set baud ...
115200
Set baud Done
Check flash ...
current eeprom imei: 355222010843713
current otp imei: 355222010173855
file saved: C:\Program Files\InfinityBox\LGA\eeprom_355222010843713_LG-KG280_20090206-144841.B1E.bin
Check flash Done
Check space ...
Check space Done
Check parameters ...
Check parameters Done
Erase ...
Erase Done
Write ...
Write: Alchemy data
Write Done
Finished, time used: 909 sec
Remove/Install battery now !
( logs is only alchemydata i try both )
FLASH WITH THIS FILE :::
KG280P64-07-V10c-000-00-JUN-08-2007_CodeData[1].B1M & KG280P64-07-V10c-000-00-JUN-08-2007_AlchemyData[1].B1P also try with format ffs
w8 for help INFINITY-TEAM
Old 02-06-2009, 18:16   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hello,
I did not understand the problem well.
What is situation after you have flashed phone with KG280P64-07-V10c-000-00-JUN-08-2007_CodeData ?
Can you make emergency call ?
What is phone imei ?
Old 02-07-2009, 09:40   #3 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
@InfinitySupport
imei is ok i flash the phone, only 1800 mhz (aritel in india )card working fine when i put other SIM is say INSERT SIM . no i think u understand my problme.
Old 02-07-2009, 16:48   #4 (permalink)
Member: 130995
1. with Airtel sim card phone works well
2. with other sim card phone show "INSERT SIM"
is it correct ?
Old 02-09-2009, 04:49   #5 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
is it correct ?
yes sir know u understand my problem
Old 02-09-2009, 09:47   #6 (permalink)
Member: 130995
Hello,
If you have the same problem after flash, you need to check phone hardware, check sim card holder, power etc., try to test phone with other sim card types. "INSERT SIM" is a hardware problem in many cases.
Old 02-09-2009, 11:09   #7 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
Hello,
ok if u right but when i put fail sim (900mhz) then it work fine
( fail SIM means REGISTRATION FAILED, IN fail SIM no network but we check menu etc . )
Old 02-09-2009, 11:22   #8 (permalink)
Member: 130995
Hello,
Try to use another one sim card and see results. It may be that phone can accept one sim card and can not accept other sim card due to hardware problem.
Old 02-09-2009, 11:39   #9 (permalink)
Chandreshswami's Avatar
Member: 370998
Sonork: 100.1582579
Thanks Meter: 218
problem is whenver 900mhz working card inserted shows insert sim
but If we insert 900mhz failed ( sim registration failed) it accept but no netwok as card is not registered
why because when we insert working 900mhz sim,it is searching for 900mhz network
so whenever it is inserted can not access and shows INSERT SIM.
may be 900mhz locked
while in 1800Mhz there is no problem
try to unlock and then post results
correct me if im wrong
Chandresh
this also sometimes happens in LG KG110 locked with
Airtel ( 1800 Mhz )
The Following User Says Thank You to Chandreshswami For This Useful Post:
Old 02-09-2009, 11:43   #10 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
Thanks bro but i allready try unlock after the flash but same problem
Old 02-09-2009, 11:53   #11 (permalink)
Member: 130995
"INSERT SIM" means phone do not see sim card (the same as sim card is missing). I think it can not be related with band. In some cases it may be related with operator lock (see below).
Airtel ( 1800 Mhz )
"INSERT SIM" for Airtel phones (with Airtel firmware) may be a result of Airtel firmware protection, but if you flash phone with non-Airtel firmware you do not see "INSERT SIM" message.
But in our situation with KG280: phone already was flashed with firmware without protection, so I think that it may be only one reason for "INSERT SIM" with some cards - phone can not read some cards (probably due to phone hardware is damaged).
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 02-09-2009, 12:31   #12 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
Thanks InfinitySupport for help yes i think is H/W problem i try with some other tools to unlock but same problem
http://forum.gsmhosting.com/vbb/show...69#post4140369
Old 02-10-2009, 06:02   #13 (permalink)
sanjubhai's Avatar
Member: 386868
Thanks Meter: 125
dear sir just repair the imei and repair the eprom and you will get the results
wbr: sanjubhai............
Pls Cyclone team help me in this probleme in Box [SOLVED] nasirns Cyclonebox 6 01-20-2010 16:52
team look this unlock problem in kg280 supportallgsm Infinity-Box 1 09-07-2009 18:46
Please Infinity Team Solve This Problem For The Main Support Site tsarkh Infinity-Box 5 05-22-2008 10:44
Could Infinity-Box fix this problem in LP Editor? GuruKids Infinity-Box 13 03-18-2008 21:47
Page generated in 0.45559 seconds with 8 queries
