02-21-2011, 11:40 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | |
03-20-2011, 10:21 | #8 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | this is infinity box section,just show the user how to unlock g3610 using infinity,not advetising other box in this section,thanks Last edited by YellowBoss; 03-20-2011 at 11:56. |
The Following User Says Thank You to KYEJUSA For This Useful Post: |
03-25-2011, 09:11 | #9 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Pakistan
Member: 313337 Status: Offline Sonork: 100.1582697 Thanks Meter: 106 | g136 successfully unlock with infinity read code witrh infinity with pinfinder example 185 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 173 byte(s) read reading data... 972 byte(s) read lock[1] code: + 24225330 (enter this code inthe mobile with other sim) lock[2] code: + 56781234 lock[3] code: + 1122 lock[4] code: - 3344 lock[5] code: - 5566 lock[6] code: + 7788 lock[7] code: + 9900 if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original thanks to you all by gsmzaman |
The Following User Says Thank You to muhammad khalid For This Useful Post: |
03-26-2011, 01:30 | #10 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
07-26-2011, 06:59 | #11 (permalink) |
Freak Poster Join Date: Dec 2007 Location: kotli
Member: 643478 Status: Offline Sonork: 100.161898 Thanks Meter: 159 | ufone huwaei g 3610 unlock done COM8 [Serial2] selected module v3.97 Action: read unlock codes unlock method: read codes Model: Huawei-G3610 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:748E:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: G3610_V100R001B001C19SP03S Version: L75_HW 80 byte(s) read imei: 35398504429141 connection Ok 185 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 173 byte(s) read reading data... 972 byte(s) read lock[1] code: + 93040687 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if phone do not ask for a code try: *983*8284# if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone (do not remove battery) - read unlock codes - restore original imei Finished, time used: 12 sec Remove/Install battery now ! |
07-30-2011, 08:14 | #12 (permalink) | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
