Old 04-02-2011, 07:45   #1 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
Infinity Team please help
client bring motorola WX395
he wanted russian language
i read its fullflash before doing anything
its fullflash
Motorola-WX395_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07 _28_SP1_V38
__fullflash_part_1_of_1_20110402-105251.B0M.bin it is 8mb
then i download from support this file
M395X-2BALUA1-27G_XJ27YJ7A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_ 06B_W07_28_SP1_V38
_2009-10-27_En_Ru_Ua.B0M.bin it is 7mgb
after writing flash file phone is working but with simcard rebooting
i put ticks at
smart write
format FFS
unlock during flash
here is log
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
chip: 0001:4A03:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC240200000000:08EA0000000000
flash: Samsung K5L2833ATA T 16Mb
otp offset: 00FF0000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader (chip) is present: 00020000
searching rom info...
search rom info finished
rom info structure: [protected] type (05), 1 record(s)
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.F153F E08.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN_D5D1415C].rpl
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: F153FE08
rom info ver: 05
sw version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN
project-id: MAUI.06B.W07.28.SP1.V38, 5C41D1D5
code offset: 00020000
ffs offset/size [01]: 00C00000/00400000
TCL-ID identification
version: 27G
provider: M395X-2BALUA1
customization: CJ27YJ7A
customization: XJ27YJ7A
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 00C00000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
product id: JRD_COMMUNICATION_B82X_PRODUCTS
area1 is invalid
area2 is invalid
area3 is valid
area4 is invalid
searching sec info#2...
search sec info#2 finished
sim-lock status: disabled
area1 is invalid
area2 is valid
area3 is valid
area4 is invalid
searching sec info#3...
search sec info#3 finished
area1 is invalid
area2 is valid
area3 is valid
area4 is valid
number of sec info areas: 3
detecting firmware version...
firmware version: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN
detecting firmware build...
firmware date/time: 2009-10-27 22-31
hw1: JRD25_06B_HW
hw2: 06B_JRD25_06B
done
detecting product-id...
product-id: B82X
detecting languages...
language parameters detected
detected languages: En Ru Ua
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: Motorola-WX395_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07 _28_SP1_V38__ffs...
file saved: C:\Program Files\InfinityBox\MModule\Motorola-WX395_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07 _28_SP1_V38__ffs_20110402-112921.B0E.bin
original imei: FFFFFFFFFFFFFF
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
firmware patch (sp-lock #1)...
not required
firmware patch (sp-lock #2)...
not required
Special operation Done
====> Write ...
usb bootloader (file) is present: 00020000
rom info relocation detected
startup code area #1 check...
startup code area #1 calculation...
startup code area #1 fixed
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX395_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07 _28_SP1_V38__system_log_F153FE08_D5D1415C_20110402-112927.B0X.bin
Area: Firmware
Write: Firmware
sec info (fast) detection...
security area (sec info, cust) calculation...
error: security area (sec info, cust) header is invalid
security area (sec info, hash) calculation...
..................region counter set: 01
security area (sec info, hash) detecting size...
security area (sec info, hash) detecting parameters...
security area (sec info, hash) encoding...
done
Write: security area (sec info, hash)
security area (sec info, hash) calculation done
identification header detected
relocation table detected
name table[00] #7000000 detected
customization name adjusted
customization detected: CJ27YJ7A
Write: security area (sec info, cust)
security area (sec info, cust) calculation done
version is not found in database: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V38.BIN
use default security area (sec info, hash) pattern
max address is too big, should be recalculated: 08BF8000->08BF4004
done
done
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Motorola-WX395_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07 _28_SP1_V38__system_log_F153FE08_D5D1415C_20110402-113156.B0X.bin
Finished, time used: 6 min 40 sec
Remove/Install battery now !
please help what to do
Old 04-02-2011, 14:07   #2 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hello,
Did you tried to make 112/emergency call without sim card ?
What is the results ?
Old 04-03-2011, 07:12   #3 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
with 112/emergency call is also rebooting
Old 04-03-2011, 07:14   #4 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
but it was working phone i check it myself with simcard
Old 04-03-2011, 09:02   #5 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
i flashed phone with its first fullflash
Motorola-WX395_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07 _28_SP1_V38__fullflash_part_1_of_1_20110402-105251.B0M
again with simcard and without simcard rebooting
Old 04-03-2011, 14:04   #6 (permalink)
Member: 1043909
Hello,
If you have flashed phone with it's original backup - this means that phone was returned back to it's original state. So, if phone still can not make a call after original backup restore- it should be a hardware problem with phone RF part (also in some cases it was a problems with batteries).
Old 04-05-2011, 05:59   #7 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
Thanks sir i will try and will write results
Old 04-06-2011, 07:25   #8 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 668
Phone is working good and in russian language
we changed RF part
but i dont understand one moment
what detect phones rf
because other user can face with this problem
anyway thanks
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-25-1999 08:21
Page generated in 0.18622 seconds with 10 queries
