GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Infinity-Box (https://forum.gsmhosting.com/vbb/f296/)
-   -   infinity team please help about touch celebration (https://forum.gsmhosting.com/vbb/f296/infinity-team-please-help-about-touch-celebration-743091/)
/\/\A/\/| 04-30-2009 12:53
COM4 selected
module v2.81
Action: touchscreen calibration
mode: 5
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:EF03:0009
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: M6225_00J6_HLD2_00_v03
Version: MT6225_GEMINI_HW
detecting structure #2...
5 11 done
67 byte(s) read
imei: 35044801123456
connection Ok
detecting structure #5 (mode-5)...
0 done
214 byte(s) read
reading data #2...
writing data...
verification...
verification Ok
Finished, time used: 11 sec
Remove/Install battery now !
but still on pen celebration
InfinitySupport 04-30-2009 15:06
Hello,
Try to repeat calibration with other modes or with "reverse calibration" mode.
/\/\A/\/| 04-30-2009 22:57
Originally Posted by InfinitySupport (Post 4421862)
Hello,
sir i tried with other all mode and reverse calibration" show (error
InfinitySupport 04-30-2009 23:01
Hello,
What was the error exactly ?
Please, post here log.
/\/\A/\/| 05-02-2009 08:08
sir here is logs i checked after change imei but my problem is not solved
COM4 selected
module v2.81
mode: 4
Calibration order: reverse
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
5 11 done
67 byte(s) read
connection Ok
detecting structure #5 (mode-4)...
8 7 3 2error:
detection failed (4 tries)
What to do:
Try another calibration method, if still no luck:
1. make full flash backup for emergency case
2. make "format ffs"
3. Power-On phone
4. Power-Off phone by "Power" button (do NOT remove battery)
5. Repeat "Calibration" operation again
6. if still no luck read full flash and send to support with subject: touchscreen calibration failed
error: can't read required data
error: operation failed !
Finished, time used: 7 sec
farihabest 05-02-2009 08:14
COM4 selected
module v2.81
mode: 4
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
5 11 done
67 byte(s) read
connection Ok
8 7 3 2error:
What to do:
3. Power-On phone
dear brohter....I always face this problem........but solution...is........
repeat the same mode......twice or three time ...
some mode gives error box and after this you can not close the window.Close the windiw in task manager and try again..
I also repair this with many time repeating... do not worry about this... try again and again until it removes.....
GSM-XPERTS 05-02-2009 08:19
yes i am full full agree with farihabest..
/\/\A/\/| 05-03-2009 08:21
brother i check it many time but my prob is not solved but dont worry customer has gone so next time i think i got it so thanks brother
ehsas_ghum 05-03-2009 09:54
hi brother plz try with old chines miracle bcoz many user face bugs in new 2.81 plz try with 2.73 n then post thanks
/\/\A/\/| 05-04-2009 07:55
thanks brother next time i check with old version
shailccna 05-06-2009 17:43
yes sir there is bug in 2.80&2.81 so use 2.73
zeedan 05-22-2009 16:38
i have china mobile show ciliriting touch screen show any solution infinity team
ranagaurav 05-22-2009 17:10
new updates is not sucsess about tuch calibration
InfinityHelp 05-22-2009 22:21
hello!
if you can not calibrate display in ordinary way-
you can bypass it using option "bypass touchscreen calibration"
you must try all available methods (method-1, method-2 etc) until you succeed
biochemistali 05-23-2009 01:49
and more thing to add
this option does not going to repair touch system, only by passing touch checks from the software, so it is better to have all types of touch system that cost s aabpout 3 $ per touch system.
it is not good always to blame the team, one can do the dre to change the touch screen.
Page generated in 0.18972 seconds with 6 queries
