Old 04-30-2009, 12:53   #1 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 601
Unhappy infinity team please help about touch celebration
COM4 selected
module v2.81
Action: touchscreen calibration
mode: 5
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:EF03:0009
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: M6225_00J6_HLD2_00_v03
Version: MT6225_GEMINI_HW
detecting structure #2...
5 11 done
67 byte(s) read
imei: 35044801123456
connection Ok
detecting structure #5 (mode-5)...
0 done
214 byte(s) read
reading data #2...
writing data...
verification...
verification Ok
Finished, time used: 11 sec
Remove/Install battery now !
but still on pen celebration
Old 04-30-2009, 15:06   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Try to repeat calibration with other modes or with "reverse calibration" mode.
Old 04-30-2009, 22:57   #3 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 601
Originally Posted by InfinitySupport View Post
Hello,
sir i tried with other all mode and reverse calibration" show (error
Old 04-30-2009, 23:01   #4 (permalink)
Member: 130995
Hello,
What was the error exactly ?
Please, post here log.
Old 05-02-2009, 08:08   #5 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 601
sir here is logs i checked after change imei but my problem is not solved
COM4 selected
module v2.81
mode: 4
Calibration order: reverse
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
5 11 done
67 byte(s) read
connection Ok
detecting structure #5 (mode-4)...
8 7 3 2error:
detection failed (4 tries)
What to do:
Try another calibration method, if still no luck:
1. make full flash backup for emergency case
2. make "format ffs"
3. Power-On phone
4. Power-Off phone by "Power" button (do NOT remove battery)
5. Repeat "Calibration" operation again
6. if still no luck read full flash and send to support with subject: touchscreen calibration failed
error: can't read required data
error: operation failed !
Finished, time used: 7 sec
Old 05-02-2009, 08:14   #6 (permalink)
farihabest's Avatar
Member: 617692
Thanks Meter: 306
COM4 selected
module v2.81
mode: 4
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
5 11 done
67 byte(s) read
connection Ok
8 7 3 2error:
What to do:
3. Power-On phone
dear brohter....I always face this problem........but solution...is........
repeat the same mode......twice or three time ...
some mode gives error box and after this you can not close the window.Close the windiw in task manager and try again..
I also repair this with many time repeating... do not worry about this... try again and again until it removes.....
Old 05-02-2009, 08:19   #7 (permalink)
GSM-XPERTS's Avatar
Member: 1001830
Sonork: 100.1652282
Thanks Meter: 242
yes i am full full agree with farihabest..
Old 05-03-2009, 08:21   #8 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 601
brother i check it many time but my prob is not solved but dont worry customer has gone so next time i think i got it so thanks brother
Old 05-03-2009, 09:54   #9 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
hi brother plz try with old chines miracle bcoz many user face bugs in new 2.81 plz try with 2.73 n then post thanks
Old 05-04-2009, 07:55   #10 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 601
thanks brother next time i check with old version
Old 05-06-2009, 17:43   #11 (permalink)
shailccna's Avatar
Member: 350232
Thanks Meter: 207
yes sir there is bug in 2.80&2.81 so use 2.73
Old 05-22-2009, 16:38   #12 (permalink)
Member: 1015645
Thanks Meter: 114
i have china mobile show ciliriting touch screen show any solution infinity team
Old 05-22-2009, 17:10   #13 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
new updates is not sucsess about tuch calibration
Old 05-22-2009, 22:21   #14 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
if you can not calibrate display in ordinary way-
you can bypass it using option "bypass touchscreen calibration"
you must try all available methods (method-1, method-2 etc) until you succeed
Old 05-23-2009, 01:49   #15 (permalink)
biochemistali's Avatar
Member: 190344
Thanks Meter: 280
and more thing to add
this option does not going to repair touch system, only by passing touch checks from the software, so it is better to have all types of touch system that cost s aabpout 3 $ per touch system.
it is not good always to blame the team, one can do the dre to change the touch screen.
The Following User Says Thank You to biochemistali For This Useful Post:
Infinity Team please help me to activate my pinfinder with my New Infinity Box NawabN Sahoo Infinity-Box 3 11-17-2009 13:50
infinity team please help about touch celebration /\/\A/\/| Chinese Models & Cloned Phones 3 04-30-2009 12:22
infinity team please help about A898 babaformula Infinity-Box 3 03-15-2009 09:34
Infinity Team Please help with my Infinity.... ASHRIFF Infinity-Box 1 03-10-2008 16:51
infinity team plsssss help about c168i rk19801 Infinity-Box 3 12-15-2007 21:18
Page generated in 0.24535 seconds with 9 queries
