Old 05-04-2017, 15:54   #1 (permalink)
seyram's Avatar
Member: 1759904
Thanks Meter: 6
Infinity team please help with error reading info
I want to flash Huawei y336-u02 spd 7731 but when i put usb cable i only get this error from cm2.
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 73 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
Boot failed!
Boot failed!
Reconnect Power/Cable!
please help me with what to do to solve problem
Old 05-04-2017, 16:25   #2 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,336
3. Insert cable
Phone found! [ 73 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Select correct boot first,hold Vol- key,insert cable.
Old 05-04-2017, 16:27   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,543
Secure huawei require correct SLDR or factory file.
The Following User Says Thank You to JayDi For This Useful Post:
Old 05-04-2017, 16:34   #4 (permalink)
seyram's Avatar
Member: 1759904
Thanks Meter: 6
Loading : Y336-U02V100R001C567B110.pac
CRVersion : BP_R1.0.0
PacCPUinfo : SC7731_2341A
PacVersion : Y336-U02V100R001C567B110
FastCheck : 0x00507DF084
Loading files ...
File : fdl1.bin
File : fdl2.bin
File : wnvitem.bin
File : wcnnvitem.bin
File : u-boot-spl-16k.bin
File : wmodem.bin
File : wdsp.bin
File : wcnmodem.bin
File : boot.img
File : recovery.img
File : system.img
File : userdata.img
File : logo.bmp
File : logo_1.bmp
File : sysinfo.img
File : customspc.img
File : prodnv.img
File : cache.img
File : u-boot.bin
File : dlstat.bin
File : globalinfo.img
File : SC7731_2341A_SB.xml
Load Ok!
Operation : Check/Read Info [ v1.24 ]
3. Insert cable
Phone found! [ 73 ]
Port Opened
Sync...
Sync...
Sending FDL
PickUp loaders from pac
Boot failed!
Boot failed!
loaded correct file but still, any help?
Old 05-04-2017, 16:46   #5 (permalink)
JayDi's Avatar
Member: 462970
That device have 2 HW versions with different RAM.
Old 05-04-2017, 17:05   #6 (permalink)
seyram's Avatar
Member: 1759904
Thanks Meter: 6
So please help me with what i should do and if you have both firmware can you provide me with them
Old 05-04-2017, 17:09   #7 (permalink)
JayDi's Avatar
Member: 462970
I have just one, which on support. Check over search about other.
Old 05-04-2017, 17:16   #8 (permalink)
seyram's Avatar
Member: 1759904
Thanks Meter: 6
how can i no the difference if i cant read phone info and please can you help with the link for yours
Old 05-04-2017, 17:44   #9 (permalink)
helpo's Avatar
Member: 2175357
Sonork: QQ:2157039171
Thanks Meter: 385
first check the the version 109-108-110
you can check in recovery
then flash with select correct pac File and version
in support area flash file is 110
i test it and not bot ith me download fro here
and enjoy
Page generated in 0.29427 seconds with 7 queries
