11-28-2018, 09:38 | #1 (permalink) |
Freak Poster Join Date: May 2012 Location: GHANA
Member: 1759904 Status: Offline Thanks Meter: 6 | infinity team please help phone DEAD Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2122 EMICFG_NOT_ACCEPTED_CONFIG Boot Error! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! |
11-28-2018, 09:45 | #2 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
The Following User Says Thank You to Kirumira For This Useful Post: |
11-28-2018, 15:01 | #3 (permalink) |
Member: 1759904 Status: Offline Thanks Meter: 6 | Got some functions back and here are logs, now seem no error but phone screen not come on please i need all help to revive phone. Jay Di and all members please help me. Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420D120FA8B83461 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xA922996A1D7583BC60605A791AB936D9 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : TECNO ProdName : H501 ProdModel : TECNO Camon CX Device : TECNO-CX AndroidVer: 7.0 MTKxCPU : MT6755 MTKxPRJ : CX-H501D1-N-170303V91 Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
11-28-2018, 15:27 | #4 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Try read info with CM2 v2.02 to give us more details about phone before dead Also u can look for working device, just backup and write backup firmware on fault phone |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
11-28-2018, 15:36 | #5 (permalink) | |
Do you want SCREEN/LCD or SCREENSHOT/LOGS DONE BY PROVIDED SOFTWARE ? Check here http://forum.gsmhosting.com/vbb/f296...shing-2441876/ | |
11-28-2018, 16:02 | #6 (permalink) |
Member: 1759904 Status: Offline Thanks Meter: 6 | thia is flash ic test. please i dont have Try read info with CM2 v2.02 installed yet and also phone was working and after format stuck in boot then i tried to flash Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : PRELOADER DRAM already initialized by Preloader Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420D120FA8B83461 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xA922996A1D7583BC60605A791AB936D9 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : HIGH-SPEED Boot Ok! [Processing] FlashMemory Read-Write test [eMMC] : [SAMSUNG] , BM31E , 0x3A3E00000 , 14910 MiB [eMMC] : CID : 150100514531334D420D120FA8B83461 [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! All Done! Done! Elapsed: 00:00:21 Reconnect Power/Cable! |
11-29-2018, 05:13 | #7 (permalink) |
Member: 1759904 Status: Offline Thanks Meter: 6 | solved it with sp flash tool and this file [Hovatek] Tecno CX (CX-H501D1-N-170405V107) cpu was mt6570. all box give me error but thanks to sp flash for the wonderful work and the sp team. once again thank you team members. After write invalid imei but used cm2 write and phone working. |
The Following User Says Thank You to seyram For This Useful Post: |
