Old 03-11-2016, 13:01   #1 (permalink)
vishnudatt's Avatar
Member: 1306196
Sonork: 100.1654602
Thanks Meter: 1,578
Arrow zen x8i read write perfect by cm2
read
Operation : Read FullFlash [ v1.16 ]
1. Remove battery. Insert USB cable
2. Press and hold BootKey ( Skip, if use BootCable )
3. Insert battery
==== Wait for phone...
Phone found! [ 11 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending boot ...
Boot Sent , starting...
Boot Ver : Spreadtrum Boot Block version 1.2
Boot Ok
CPU ID : 6531 , FDLStat : 0100
[0] Flash DIE : 00EF 0040 0016 0000
[0] Flash VEN : Winbond , W25Q32
[0] Flash CAP : 00400000
Read Flash Content
Read Ok , collect info
Set FileInfo :
Model Vendor : x8i
Model Name : x8i
Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_00400000_W2 5Q32__x8i-x8i.bin
Done!
Elapsed: 00:00:31
Reconnect Power/Cable!
write
Operation : Flash [ v1.16 ]
======= Flash
Files set for flashing :
[ MCU ] : SPD6531_00400000_W25Q32__x8i-x8i.bin
3. Insert battery
Phone found! [ 11 ]
Port Opened
Sync...
Sync...
Sending boot ...
Boot Ok
======= Flashing MCU
Mapping file ...
Mapping done
Processing file : SPD6531_00400000_W25Q32__x8i-x8i.bin
Init ok, send data
Flashing Done!
Info : In some cases after flash required make "Format Fs / Reset Phone"
Done!
Elapsed: 00:01:10
The Following User Says Thank You to vishnudatt For This Useful Post:
Old 06-19-2017, 08:41   #2 (permalink)
Member: 442808
Thanks Meter: 195
hi can you provide me the zen x8i flash file
Old 06-20-2017, 08:55   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
Dear Sirs,
If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool
Page generated in 0.15143 seconds with 8 queries
