03-05-2011, 05:31 | #1 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Cambodia
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | Infinity team Pls check MF6201 COM46 [VCP0] selected module v3.78 Device: Metfone-MF6201 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:7BCB:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:2AEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent rom info detection finished rom info ver: 07 sw version: ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.CB-MF-R9SM-P109A17V1_0_1B03.BIN project-id: CB-MF-R9SM-P109A17V1.0.1B03, 00000000 code offset: 00000000 ffs offset/size [02]: 00880000/00780000 rom info structure: [standard] type (07) TCL-ID is absent ffs/eeprom address assigned: 00880000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Metfone-MF6201_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.CB-MF-R9SM-P109A17V1_0_1B03__ffs... file saved: C:\InfinityBox\MModule\Metfone-MF6201_ZTENJ23D_09A_PCB01_GPRS_MT6223_S00.CB-MF-R9SM-P109A17V1_0_1B03__ffs_20110305-112351.B0E.bin flash: EC257E25082501:2AEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... .......................... required data found flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: area 1 (pass 1) ...................................... area 1 patch applied Ok detecting parameters to apply patch area 2... ................. required data found flash: EC257E25082501:2AEA0000000000 flash: EC257E25082501:2AEA0000000000 Write: area 2 (pass 1) ............................................... area 2 patch applied Ok Special operation Done ====> Write ... flash: EC257E25082501:2AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 6 min 39 sec Remove/Install battery now ! and now my phone show this Pls help me. thanks. Last edited by 089999945; 03-05-2011 at 05:36. |
03-05-2011, 06:20 | #2 (permalink) |
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | I read code and type (code accept but not unlock) Pls help me. thanks. 86 byte(s) read imei: 86490800016577 connection Ok 192 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1234 180 byte(s) read reading data... 972 byte(s) read lock[1] code: + 942938165170 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 13 sec Remove/Install battery now ! |
03-05-2011, 08:55 | #3 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, First make full backup of your phone. Did you try with other unlock method, like smart-fast, standard fast? Also you can try repair security area option. P.S. this model Metfone-MF6201 still under test Wbr. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
03-05-2011, 15:47 | #4 (permalink) | |
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | Quote:
Pls help me all user and infinity team or must be wait? thanks. | |
03-07-2011, 17:43 | #5 (permalink) | |
Please, try to flash your phone with different ZTE-R221 flash files from support area. What is the results ? Also, do you have original full flash backup file ? If you have it, please, send it to [email protected] | |
03-08-2011, 03:23 | #6 (permalink) | |
send full flash to u already. thanks. | |
03-08-2011, 03:55 | #7 (permalink) | |
Hello sir. when i flash it with ZTE-R221 is ok and can unlock it but white screen. pls help me. thanks. | |
03-08-2011, 10:00 | #8 (permalink) | |
Please, make this test: 1. flash phone with different R221 firmware files from support area and see results. I think one firmware should be good for your phone 2. if still no luck, try to flash phone with SFR-115 flash files one by one. Waiting for your results. | |
03-08-2011, 10:40 | #9 (permalink) | |
i don't understand. u mean check in support flash like this ZTENJ23D_09A_PCB01 , i must test all ? pls tel me. thansk. | |
03-08-2011, 10:53 | #10 (permalink) |
Member: 1260512 Status: Offline Sonork: 100.1605447 Thanks Meter: 461 | Now is ok 100% thank so much infiti team. pls good luck 4 u. and after i'll test HL2802. COM46 [VCP0] selected module v3.79 Action: read unlock codes unlock method: read codes Model: Metfone-MF6201 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:490F:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: EFS-SFR-R9SM-P109A17V1.0.4B02 Version: ZTENJ23D_09A_HW 86 byte(s) read imei: 86490800016684 connection Ok 192 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 180 byte(s) read reading data... 972 byte(s) read lock[1] code: + 804738444660 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 11 sec Remove/Install battery now ! Last edited by 089999945; 03-08-2011 at 11:03. |
The Following User Says Thank You to 089999945 For This Useful Post: |
Check this New Nokia Tool.. | tronix | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 06-01-2001 10:24 |
5110 V 5.30 CHECK SIM | gsnbhagawan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-21-2001 06:45 |
Wanted 6130 4.02 full backup Pls Read | Charly | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-06-2001 05:12 |
check out my FREE large gsm soft site | LaLGsm | GSM Mobile Links | 0 | 01-16-2001 04:36 |
FBUS works but MBUS not! PLS Help! | Upo | Nokia Hardware & Hardware Repair | 5 | 09-12-2000 14:54 |
