11-26-2008, 05:15 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: philippines
Member: 699870 Status: Offline Sonork: 100.1647674 Thanks Meter: 69 | infinity team pls help heres a log module v1.54 Device: ZTE-125 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-sta... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sta_20081125-192450.B1E.bin loading data... data loaded reading eeprom-sec... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sec_20081125-192453.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20081125-192500.B1E.bin reading additional data... done backup critical area Done Check memory ... current status: #2, already unlocked already done (mode-0), operation aborted Check memory Failed Finished, time used: 32 sec Remove/Install battery now ! |
11-26-2008, 05:40 | #2 (permalink) |
Member: 699870 Status: Offline Sonork: 100.1647674 Thanks Meter: 69 | were sleeping,, but any thanks the phone is allready unlocked now.. COM4 [VCP0] selected module v1.57 Device: ZTE-125 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: -DE-P108A1V1.0.0B02 VDF-P108A1B07-De-DE03 g3dBV2.0 16 59 13 04.1 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-static_20081126-123216.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-security_20081126-123217.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20081126-123223.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_lock-area_20081126-123229.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 36 sec Remove/Install battery now ! |
The Following User Says Thank You to arabie For This Useful Post: |
11-26-2008, 09:23 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, It's a good example that users should visit support area from time to time and download latest updates due to we make improvements in software every day, add new models and improve operations for old models. |
12-07-2008, 09:54 | #5 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | here it is Cable name: ZTE-225 keyboard top 1..........8 1: phone Tx (RJ-45 pin-3) 2: phone Rx (RJ-45 pin-2) 3: Gnd BR Faisal_Computer |
12-07-2008, 11:34 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is information how to build your own cable: http://forum.gsmhosting.com/vbb/showthread.php?t=342807 |
infinity team pls help??? e71+ firmware. help??nfinity team pls. help?? | vintel | Infinity-Box | 4 | 03-07-2010 11:29 |
Infinity team pls help | vpriya | Infinity-Box | 3 | 10-17-2009 16:49 |
infinity team pls... help! | tabuki | Infinity-Box | 2 | 12-23-2007 09:02 |
Infinity Team pls help me | jhay_12 | Infinity-Box | 8 | 08-27-2007 10:32 |
infinity team pls help for c261 unlock user lock | siang8788 | Infinity-Box | 4 | 01-13-2007 20:05 |
