03-06-2010, 11:50 | #1 (permalink) |
Insane Poster Join Date: May 2008 Location: celtaq pinas
Member: 767344 Status: Offline Thanks Meter: 26 | infinity team pls help??? e71+ firmware. help??nfinity team pls. help?? i have downloaded from support of this kind of file and it shows this http://www.mediafire.com/?10dw4woqnogthis is my backup files im not sure if its working and this the file i have downloaded from support http://www.mediafire.com/?orznkvmtmnn pls help |
03-06-2010, 12:36 | #2 (permalink) |
No Life Poster Join Date: Aug 2004 Location: With old & new friends Age: 49
Member: 79640 Status: Offline Sonork: 1577251 Thanks Meter: 238 | Your are using Outdated Chinese Miracle Module, update it and retry ! Regards |
The Following 3 Users Say Thank You to dzunlocker For This Useful Post: |
03-07-2010, 11:07 | #3 (permalink) |
Member: 767344 Status: Offline Thanks Meter: 26 | problem solved! thanks sir dzunlocker my box was outdated...thanks for the tip COM7 [VCP0] selected module v3.10 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware R202_FN_PCB01_GPRS_MT6225_S00.R202_GH_S202_F13_V07 _091027__E71+_16m_En_Ru_Fr_Es_It_Pl_Ml_Id_Th_Vn_Tr _Farsi_Pt_Ar.B0M(2).bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot Off chip: 0001:5803:0001 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:2AEA0000000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 05 sw version: R202_FN_PCB01_GPRS_MT6225_S00.R202_GH_S202_F12_V02 _090730.BIN project-id: R202_GH_S202_F12_V02_090730, 00000000 code offset: 00000000 ffs offset/size [01]: 00E60000/001A0000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E60000 flash: EC240200000000:2AEA0000000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E60000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 001A0000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E60000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: R202_FN_PCB01_GPRS_MT6225_S00.R202_GH_S202_F12_V02 _090730__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\R202_FN_PCB01_GPR S_MT6225_S00.R202_GH_S202_F12_V02_090730__ffs_2010 0307-174940.B0E.bin flash: EC240200000000:2AEA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: EC240200000000:2AEA0000000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 10 min 58 sec Remove/Install battery now ! here's the screen shot yahoo........ more power infinity team |
Verzio/duplii pinout pls. Great infinity team help! | venuno | Infinity-Box | 11 | 04-29-2010 07:09 |
hello infinity team plss add this firmware n95-8g | ayhen42 | Infinity-Box | 5 | 11-11-2008 19:52 |
nfinity team pls help mpeg4 p888 | jbbasha | Infinity-Box | 13 | 10-13-2008 21:45 |
Infinity Team Have Firmware For Mpeg4 A960?????? Please Help | torpedo_seluler | Infinity-Box | 6 | 06-03-2008 08:23 |
