Infinity team pls help me 2 Attachment(s) I Install infinity & its driver but cannot run infinity pls solve my problem. |
problem is not about your driver, but chek your Os,and disable antivirus. if you want to know whats problem,install to other Pc,or reinstal your Os. |
"Infinity-Box Shell" is just a small part of Infinity-Box software. You must download from support area and install "Infinity-Box Main installation package". After installation you will have all required software at your PC. |
i have lgkg290 set when i on set show kg290 on stand i have write eprom but same problem here is log COM4 [VCP0] selected module v1.39 Device: LG-KG290 Checking data, wait... advanced flash detection enabled Action: flash write Skip: Firmware (code) Skip: File system Skip: Alchemy data Write: Eeprom "smart write" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 357456017537328 file saved: C:\Program Files\InfinityBox\LGA\eeprom_357456017537328_LG-KG290_20100331-113920.B1E.bin .............. version: D-9DGDKG290P40 Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Eeprom flash: 89881600010001:89881600000000 Write Done Finished, time used: 29 sec Remove/Install battery now ! |
