Infinity team pls help regarding firmare error Dear Sir, I have one China set with me "ZTC ZT8089" it was not taking sim, I read full detailed on infinity and read the version of firmware, After that i download all firmwares from the infinity support area and write it on the phone but nightmare start, Now it give white display, all keys are in working position. pls help me to sove this situation. Regards, |
first why u flashed the set if u can repair it with just formatffs. now if u readed full flash then flash it again with readed flashfile. did u flashed it with same version which it was earlier have. just paste here earlier firmware version of phone . i will upload fille here. next time always first keep backup of phone may it be any condition |
read flash any same working set and then flash. ;) |
Sir, many thanks for your kind reply, i deal with the phone following with full details, 1. First of all i do safe format but nothing 2.than i do full format but all in vain 3.than i go "Service Tab" and do "Read Detailed information" 4.After reading detailed information i find firmware vesrion which is MT6225_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_08_M P_V27 after coping it , i go to the support area and than flash files area, i paste firmware version in search and press search, Result give 6 firmware and 3 eeprom files 5. I select ZTC-ZT188_MT6225_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W0 7_08_MP_V27_16m_En_Cn.B0M and download it. 6.After downloading and write it on the phone, Set goes on white display. 7.Later i load original backup eeprom file and write it on the phone, Now it give ring starting phone but display still white, 8. I try all 6 firmwares(in result of search) but all in vain. Now kindly suggest me your valuable suggestions. Following is "READ DETAILED INFORMATION", COM7 [Serial2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:0003:000F boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.4EBD8055.[MT6225_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_08_M P_V27.BIN_851A4F04].rpl New firmware detected: MT6225_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_08_M P_V27.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) identification#1 detection finished device-id: 4EBD8055 identification#1 protocol ver: 04 ver. sw1: MT6225_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_08_M P_V27.BIN ver. sw2: MAUI.06B.W07.08.MP.V27, FBB0E57A ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... ...................... detect standard fat location pass #1... .................................................. ..... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #1 detected ok detecting ffs structure pass 2... ...................... detect standard fat location pass #1... .................................................. ..... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs element #2 detected ok Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _4EBD8055_MT6225_06B_PCB01_GPRS_MT6225_S00.MAUI_06 B_W07_08_MP_V27.BIN_851A4F04_20081112-032102.B0X.bin Finished, time used: 85 sec Remove/Install battery now ! |
look here for the file and flash again https://ssl.rapidshare.com/cgi-bin/collectorszone.cgi? user standard_mukerian pass mukerian |
@Mr. Right If you have flashed phone with other firmware you have no reason to restore eeprom. If you want to restore phone to it's original state you need to restore full flash backup (that contain firmware + eeprom). Also I suggest you to check text in software log window very carefully every time but not ignore it. Please, read your own previous message now very carefully. |
Dear Tajinder, Thanks for your support, I login and found 1 file for my purpose, i download it and write it on the phone with eprom. Now its totally dead. I try to on with power supply, ampere jumping from o to 0.1 again and again but did not getting boot. i push button more than 2 minutes continuosly but all in vain. pls suggest me other solution I also request INFINITY TEAM to try to provide me ACCURATE FIRMWARE, so that i can solve this critical problem. I try to load backup data but it give me erro. pls guide me again. |
Infinity team kindly try to provide me exactly "firmware" after reading my whole "Read Detailed information. i will be thankful for your kind information. |
@Mr. Right Check log text that you have posted: Code: New firmware detected: It will be good if somebody can read full flash from the same good working phone and send full flash backup to [email protected] so we will be able to prepare and upload good working files in support area for all users. |
@Infinity team Will my logbackup and firmware backu+eeprom backup help you to solve this? if yes than i can send you. pls inform |
Hello, If you have original flash backup then flash it back and phone will be in it's original state. Do you have original flash backup before any operations ? |
@mr right who said u to write eeprom with my file. just flash it with the file on my link. its full readed flash file. after flash if phone cannot power on just do complete ffs after flash. |
Dear Tajinder, I am thankful to you again for your care and support. I do same as you tell me, write firmware without eeprom but it did not start, than i do full format , during format a window appear about eeprom says like " cannot detect eeprom erea, press ok if you are sure aboutStandar 0eee00 area if not than no" If i press yes, reslut in previous condition, i mean supllly hand move from 0 to 0.1 again and again if i press no, reslut in hand move up a little bit countinously but could not start, will you kind enough to guide me more thanks again |
hello! if you cant find same working phone to use its full backup- you can try to flash some firmares from our support site. i know, you already did this, but your mistake was not doing Format FFS complete after each flashing |
@infinity team, Thanks for your suggestion, I also try again it. kindly suggest i write firmware withth eeprom or without eeprom Plus i find New firmware of chinese mobile, soon i send it to you to make update. regards, Mr. Right. |
