Old 11-13-2008, 17:56   #1 (permalink)
Mr. Right's Avatar
Member: 796514
Sonork: 100.1583845
Thanks Meter: 53
Infinity team pls help regarding firmare error
Dear Sir,
I have one China set with me "ZTC ZT8089"
it was not taking sim,
I read full detailed on infinity and read the version of firmware,
After that i download all firmwares from the infinity support area and write it on the phone but nightmare start,
Now it give white display, all keys are in working position.
pls help me to sove this situation.
Regards,
Old 11-13-2008, 18:12   #2 (permalink)
tajinder's Avatar
Member: 181825
Thanks Meter: 187
first why u flashed the set if u can repair it with just formatffs.
now if u readed full flash then flash it again with readed flashfile.
did u flashed it with same version which it was earlier have. just paste here earlier firmware version of phone . i will upload fille here.
next time always first keep backup of phone may it be any condition
The Following User Says Thank You to tajinder For This Useful Post:
Old 11-13-2008, 18:22   #3 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
Thanks Meter: 3,176
read flash any same working set and then flash.
The Following User Says Thank You to NADEEM GONDAL For This Useful Post:
Old 11-13-2008, 19:07   #4 (permalink)
Mr. Right's Avatar
Member: 796514
Sonork: 100.1583845
Thanks Meter: 53
Sir, many thanks for your kind reply, i deal with the phone following with full details,
1. First of all i do safe format but nothing
2.than i do full format but all in vain
3.than i go "Service Tab" and do "Read Detailed information"
4.After reading detailed information i find firmware vesrion which is
MT6225_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_08_M P_V27
after coping it , i go to the support area and than flash files area,
i paste firmware version in search and press search,
Result give 6 firmware and 3 eeprom files
5. I select
ZTC-ZT188_MT6225_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W0 7_08_MP_V27_16m_En_Cn.B0M
and download it.
6.After downloading and write it on the phone, Set goes on white display.
7.Later i load original backup eeprom file and write it on the phone, Now it give ring starting phone but display still white,
8. I try all 6 firmwares(in result of search) but all in vain.
Now kindly suggest me your valuable suggestions.
Following is "READ DETAILED INFORMATION",
COM7 [Serial2] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:0003:000F
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.4EBD8055.[MT6225_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_08_M P_V27.BIN_851A4F04].rpl
New firmware detected:
- make "Read full flash" operation
- send "backup_system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 4EBD8055
identification#1 protocol ver: 04
ver. sw1: MT6225_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_08_M P_V27.BIN
ver. sw2: MAUI.06B.W07.08.MP.V27, FBB0E57A
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
detecting ffs structure pass 2...
ffs element #2 detected ok
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _4EBD8055_MT6225_06B_PCB01_GPRS_MT6225_S00.MAUI_06 B_W07_08_MP_V27.BIN_851A4F04_20081112-032102.B0X.bin
Finished, time used: 85 sec
Remove/Install battery now !
Old 11-14-2008, 14:13   #5 (permalink)
tajinder's Avatar
Member: 181825
Thanks Meter: 187
look here for the file and flash again
https://ssl.rapidshare.com/cgi-bin/collectorszone.cgi?
user standard_mukerian
pass mukerian
Old 11-14-2008, 20:33   #6 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,399
@Mr. Right
If you have flashed phone with other firmware you have no reason to restore eeprom.
If you want to restore phone to it's original state you need to restore full flash backup (that contain firmware + eeprom).
Also I suggest you to check text in software log window very carefully every time but not ignore it.
Please, read your own previous message now very carefully.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 11-15-2008, 12:05   #7 (permalink)
Mr. Right's Avatar
Member: 796514
Sonork: 100.1583845
Thanks Meter: 53
pass mukerian
Dear Tajinder,
Thanks for your support, I login and found 1 file for my purpose, i download it and write it on the phone with eprom. Now its totally dead. I try to on with power supply, ampere jumping from o to 0.1 again and again but did not getting boot. i push button more than 2 minutes continuosly but all in vain.
pls suggest me other solution
I also request INFINITY TEAM to try to provide me ACCURATE FIRMWARE,
so that i can solve this critical problem.
I try to load backup data but it give me erro.
pls guide me again.
Old 11-15-2008, 18:37   #8 (permalink)
Mr. Right's Avatar
Member: 796514
Sonork: 100.1583845
Thanks Meter: 53
Infinity team kindly try to provide me exactly "firmware" after reading my whole "Read Detailed information.
i will be thankful for your kind information.
Old 11-15-2008, 22:01   #9 (permalink)
Member: 130995
@Mr. Right
Check log text that you have posted:
@all
It will be good if somebody can read full flash from the same good working phone and send
full flash backup to [email protected] so we will be able to prepare and upload
good working files in support area for all users.
Old 11-16-2008, 09:16   #10 (permalink)
Mr. Right's Avatar
Member: 796514
Sonork: 100.1583845
Thanks Meter: 53
@Infinity team
Will my logbackup and firmware backu+eeprom backup help you to solve this?
if yes than i can send you.
pls inform
Old 11-16-2008, 10:42   #11 (permalink)
Member: 130995
Hello,
If you have original flash backup then flash it back and phone will be in it's original state.
Do you have original flash backup before any operations ?
Old 11-17-2008, 04:47   #12 (permalink)
tajinder's Avatar
Member: 181825
Thanks Meter: 187
@mr right
who said u to write eeprom with my file. just flash it with the file on my link. its full readed flash file. after flash if phone cannot power on just do complete ffs after flash.
Old 11-18-2008, 12:50   #13 (permalink)
Mr. Right's Avatar
Member: 796514
Sonork: 100.1583845
Thanks Meter: 53
Dear Tajinder,
I am thankful to you again for your care and support.
I do same as you tell me, write firmware without eeprom but it did not start, than i do full format , during format a window appear about eeprom says like " cannot detect eeprom erea, press ok if you are sure aboutStandar 0eee00 area if not than no"
If i press yes, reslut in previous condition, i mean supllly hand move from 0 to 0.1 again and again
if i press no, reslut in hand move up a little bit countinously but could not start,
will you kind enough to guide me more
thanks again
Old 11-18-2008, 19:28   #14 (permalink)
Member: 148515
Thanks Meter: 15,716
hello!
if you cant find same working phone to use its full backup-
you can try to flash some firmares from our support site.
i know, you already did this, but your mistake was not doing Format FFS complete after each flashing
Old 11-19-2008, 10:23   #15 (permalink)
Mr. Right's Avatar
Member: 796514
Sonork: 100.1583845
Thanks Meter: 53
@infinity team,
Thanks for your suggestion, I also try again it. kindly suggest i write firmware withth eeprom or without eeprom
Plus i find New firmware of chinese mobile, soon i send it to you to make update.
regards,
Mr. Right.
infinity team pls help??? e71+ firmware. help??nfinity team pls. help?? vintel Infinity-Box 4 03-07-2010 11:29
Infinity team pls help vpriya Infinity-Box 3 10-17-2009 17:49
infinity team pls... help! tabuki Infinity-Box 2 12-23-2007 09:02
Infinity Team pls help me jhay_12 Infinity-Box 8 08-27-2007 11:32
infinity team pls help for c261 unlock user lock siang8788 Infinity-Box 4 01-13-2007 20:05
Page generated in 0.43444 seconds with 8 queries
