08-18-2008, 15:43 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,691 | Toshiba Ts608 Phone Code Locked ihave RESET SETTING and phone is not unlock any solution please COM5 [VCP0] selected Device: Toshiba-TS608 Checking data, wait... advanced flash detection active Action: Reset Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22202200:98E59F00000000 flash: 01227E22202200:98E59F00000000 flash: Amd PL127J D 16Mb id: 0000527A Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/03 area-02... area requested/selected: 02/03 Format file system Done Write... Write Done Finished Remove/Install battery now ! Time used: 23 sec |
08-18-2008, 16:06 | #2 (permalink) |
No Life Poster Join Date: Jan 2005 Location: TUNISIA-KEBILI Age: 44
Member: 108627 Status: Offline Thanks Meter: 307 | hi downland the eprom file for fly 2060 from the site infinity and all will be ok. |
The Following 2 Users Say Thank You to limem2003 For This Useful Post: |
08-19-2008, 16:20 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | 1. make eeprom backup 2. follow by advice given by respected Mr. limem2003 and flash phone with this file: Fly-2060_repair_eeprom_02_clear.9FE.bin |
The Following 4 Users Say Thank You to InfinitySupport For This Useful Post: |
08-20-2008, 15:13 | #6 (permalink) |
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,691 | after flash phone with this file: Fly-2060_repair_eeprom_02_clear.9FE.bin now my phone is no network any solution |
01-07-2009, 17:38 | #13 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | @balli what is the problem exactly ? @moonfighter Your support is closed due to stupid avatar picture. You must remove/change your stupid avatar picture right now ! This forum is NOT for political games ! |
ts608 phone code locked | sonetek | FuriousGold | 1 | 03-04-2008 11:00 |
ts608 phone code locked | sonetek | Infinity-Box | 1 | 03-03-2008 23:17 |
toshiba ts10 Phone code Locked problem ? | alex12 | Infinity-Box | 2 | 11-16-2007 16:56 |
TOSHIBA TS608 Unlocking code pls | DigitalMan | Phone Unlocking Codes & Maps | 4 | 06-05-2007 23:52 |
Toshiba Ts608 Securtiy Code... | LoveLess | Various | 0 | 12-02-2006 10:23 |
