Old 07-31-2008, 13:30   #1 (permalink)
Registered User
Member: 55026
Thanks Meter: 53
6300 Erase IMEI itself, after change IMEI!!
nowadays bringme many 6300, they erase IMEI itself, after write IMEI a few hours it reset itself lang turn to chines an IMEI back to 13........
I tried many thing like complete format, flash nothing help, this is not just one hone, so it is not hardware problem.. many phones has the same problem..
plse take care about this problem infinity team..
regards..
Old 08-01-2008, 22:21   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
What is phone firmware version ?
What is flash chip type ?
Did you tried to reball flash chip ?
Old 08-02-2008, 10:14   #3 (permalink)
Registered User
Member: 55026
Thanks Meter: 53
JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN
CPU : MT6225A
FLASH IC : SPANSION 71PL127NB0HFW4U
detailed information listed below
this is not a hardware problem, this type of phones all makes this problem. one of my friend (dealer) has many that phone with same problem in hand. That's why asking you.
COM4 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:3303:0004
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E22202200:18E59F00000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.323E78B3.[JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN_E70F29F2].rpl
identification#1 detection finished
device-id: 323E78B3
identification#1 protocol ver: 04
ver. sw1: JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN
ver. sw2: MAUI.07A.W07.52.MP.V2, 0DD6F018
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
detecting ffs structure pass 2...
ffs element #2 detected ok
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_323E78 B3_JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_M P_V2.BIN_E70F29F2_20080802-121349.B0X.bin
Finished, time used: 150 sec
Remove/Install battery now !
Old 08-02-2008, 10:18   #4 (permalink)
Member: 130995
Did you tried to find and use any other similar firmware for this type of phones ?
Just an idea: phone firmware that you talk about has a bug and as a result phone eeprom become damaged after some time.
Old 08-02-2008, 13:59   #5 (permalink)
Registered User
Member: 55026
Thanks Meter: 53
and!?
how to fix that? you may have any idea...?
Old 08-02-2008, 16:11   #6 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
you can try to find similar working phone , read out flash dump and use it for flashing faulty phones.
maybe this will help
Old 08-20-2008, 16:33   #7 (permalink)
Member: 205679
Thanks Meter: 67
hi all chinese 6300 any models backup and flashing faulty phones not working imei erased 1 hour and 1 day i need working flash upload your site... thanksss..
Old 11-23-2008, 13:12   #8 (permalink)
raza786's Avatar
Member: 18418
Thanks Meter: 8
I am also having the same problem.any solution as yet.
Old 11-23-2008, 14:39   #9 (permalink)
Member: 148515
hello!
i can only advice to use similar firmware and check result.
what is your phone original firmware?
Old 11-23-2008, 19:50   #10 (permalink)
raza786's Avatar
Member: 18418
Thanks Meter: 8
This is the firmware of the phone
JIA6300_PCB01_GPRS_MT6225_S00.MAUI_07A_W07_52_MP_V 2.BIN.
Please give me another firmware close to this that will work on this phone.
Old 11-23-2008, 19:58   #11 (permalink)
ozeracar's Avatar
Member: 32738
Thanks Meter: 32
if change imei number from flash file (16 Mb) and format all is ok .
but this solution a long time
so we need short time solution
thanks infinity team ..
Old 11-27-2008, 19:26   #12 (permalink)
Member: 148515
hello guys!
nearest Cinese Miracle update will support this option (default IMEI number editing)
this will solve automaticly resetted IMEI probelm
Old 11-30-2008, 23:59   #13 (permalink)
Member: 130995
Hello,
If problem still exist there is a way: use ChineseMiracle v2.70 and repair "imei inside firmware".
After this operation even if imei will be resetted automatically it will be resetted to value that you already programmed.
Old 12-01-2008, 08:10   #14 (permalink)
raza786's Avatar
Member: 18418
Thanks Meter: 8
Thank you very much
Keep up the good support
Nokia 6300 will reboot itself after 3 min jorey Nokia Hardware & Hardware Repair 2 01-28-2010 09:01
6300 still contact service after write imei backup black snake MT-BOX 9 10-14-2007 23:21
Can't call after change IMEI. Alex1234 VLSI, Conexant, Skyworks and Old Models 14 12-10-2003 05:52
J70 after change IMEI from 0000 to normal, phone still says SIM LOCKED dannyogolo Sony 10 09-02-2003 13:36
IMPOSSIBLE to reset security code after change IMEI !!!! hanoon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 03-01-2002 18:09
Page generated in 0.24257 seconds with 9 queries
