Old 11-29-2008, 14:11   #1 (permalink)
aamirgsm's Avatar
Member: 526737
Thanks Meter: 9
Infinity team plz help me and give me flash file
Sir i need flash file xds 5310 express music
when i recive set it is dead then i write ffs complete formate after then set is gone
"bad softwere"
i read eeprom and write set is dead and no on plz asist me what should i have to do. . .
after writing the eeprom showing this error
Detected eeprom/ffs address is non-standard: 00F40000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
Do you want to use standard eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
This is full flash backup file
flash_20081128-235302.B0M
This is eeprom file
eeprom_20081128-232011.B0E
Regard's
aamirgsm
Old 11-29-2008, 15:47   #2 (permalink)
gsm2start's Avatar
Member: 894719
Sonork: 100.1580092
Thanks Meter: 905
try to use someother flash files from the support area
and choose same as the set you have try all the flash files of 5310
hopfly one of them will be the right one
regards
Old 11-29-2008, 16:42   #3 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
"bad softwere"
Posible reasons:
This is eeprom file
Regard's
aamirgsm
if u have the first EEprom backup .. then write the phone will revive.....
Old 11-29-2008, 21:00   #4 (permalink)
yawarniazi's Avatar
Member: 194128
Thanks Meter: 303
I've the flashfile of this phone, wait till tomorrow, right now I'm at home.
Best Regards!
yawarniazi
Old 11-30-2008, 07:46   #5 (permalink)
aamirgsm's Avatar
Member: 526737
Thanks Meter: 9
Dear sir when i recive this set . set is dead i write the ffs complete formate.set is gone "bad softwere"
then i write the first eeprom backup after writing the eeprom set is gone dead . . .
Regard's
aamirgsm
Old 11-30-2008, 08:00   #6 (permalink)
aamirgsm's Avatar
Member: 526737
Thanks Meter: 9
regards
sir i will download all 5310 files at the support
then i have try all the flash file and post here
Regard's
aamirgsm
Old 11-30-2008, 08:06   #7 (permalink)
aamirgsm's Avatar
Member: 526737
Thanks Meter: 9
Best Regards!
yawarniazi
Dear brother upload flash file this phone
i m waiting ur response. . .
Regard's
aamirgsm
Old 11-30-2008, 08:36   #8 (permalink)
yawarniazi's Avatar
Member: 194128
Thanks Meter: 303
Here is your desired flashfile.
http://www.4shared.com/file/73762776...V1_6_1BIN.html
After flashing if phone shows "Bad Software", simply click on "Repair Bad Software" button.
BEST OF LUCK!
yawarniazi
Old 11-30-2008, 11:58   #9 (permalink)
aamirgsm's Avatar
Member: 526737
Thanks Meter: 9
BEST OF LUCK!
yawarniazi
Dear brother thanks 4 uploading the flash file
i write these flash file set is gone bad softwere
i write ffs complete formate set is dead
plz help me . . .
Regard's
aamirgsm
Old 11-30-2008, 12:26   #10 (permalink)
yawarniazi's Avatar
Member: 194128
Thanks Meter: 303
plz help me . . .
Regard's
aamirgsm
Why are you hasitating on clicking "Repair Bad Software" button in ChineseMiracle after flash????????????????????????????????????????????? ???????????????????????
Old 11-30-2008, 14:38   #11 (permalink)
aamirgsm's Avatar
Member: 526737
Thanks Meter: 9
dear when i flash phone ur files set is gone "bad softwere"
u will advice me after flashing if phone shows "Bad Software", simply click on "Repair Bad Software" button
but i will clicking ffs complete formate and set is gone dead mode
plz help me what should i have todo
Regard's
aamirgsm
Old 11-30-2008, 14:41   #12 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
You must restore original flash backup.
Then make "Repair bad software" operation.
Old 11-30-2008, 15:07   #13 (permalink)
aamirgsm's Avatar
Member: 526737
Thanks Meter: 9
i m trying to restore the orginal backup but failed each time
Old 11-30-2008, 16:22   #14 (permalink)
Member: 130995
Hello,
What is the problem exactly ?
Post log here.
Old 12-01-2008, 08:41   #15 (permalink)
aamirgsm's Avatar
Member: 526737
Thanks Meter: 9
thanks a lot sir my problm is solve set is alive
but when i power on after few sec set is hang and set is power off
infinity is good box 4 chines mobile & infinity team is great work
Regard's
aamirgsm
infinity team plz help me qadriatta Infinity-Box 2 03-08-2009 21:46
6300 RH-37 after factory setting set is gone dead mode infinity team plz help me aamirgsm Infinity-Box 4 12-08-2008 09:39
infinity team plz help me Raja_Vickey Infinity-Box 1 09-18-2008 21:50
c140 cant unlock in infinity team plz help me ramesh_931 Infinity-Box 7 07-20-2007 17:47
Infinity team plz help me to flash for nokia E60 .::Munazzam::. Infinity-Box 7 06-27-2007 19:53
Page generated in 0.29557 seconds with 10 queries
