04-30-2009, 13:48 | #1 (permalink) |
Banned Join Date: Dec 2006 Location: inside of infinity best tool
Member: 411831 Status: Offline Thanks Meter: 215 | Infinity team plz.help spice d88n(gold)after flash white light ! INFINITY TEAM PLZ.HELP SPICE D88N(GOLD)AFTER FLASH WHITE LIGHT ! PLEASE LOOK THIS OPRATION LOG................ COM8 [VCP0] selected module v2.69 Action: reset settings Model: Spice-D88 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6219:8B02:8B01]... CPU: MT6219 chip: 0031:B5C1:EA3E status: FF detected CPU: MT6226MA Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226M,E02 Date: 2005.04.12 Version: 1.0 Version: 1.06 Version: GC216_HW 65 byte(s) read imei: FFFFFFFFFFFFFF connection Ok building list... done items to clear: 151 warning: wrong packet cs items cleared: 151 of 151 building list... done items remains: 0 Finished, time used: 116 sec ================================================== = Action: imei Model: Spice-D88 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226M, E0 Hardware version: GC216_HW Software version: 1.06" Software date: 2005.04.12 Barcode: VG8A18M00929 imei: 358071020092945 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei: 358071020092945 verification Ok Finished, time used: 7 sec Power off phone now ! ================================================== ==== COM8 [VCP0] selected module v2.69 Action: reset settings Model: Spice-D88 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6219:8B02:8B01]... CPU: MT6219 chip: 0031:B5C1:EA3E status: FF detected CPU: MT6226MA Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226M,E02 Date: 2005.04.12 Version: 1.0 Version: 1.06 Version: GC216_HW 65 byte(s) read imei: 415161718191A1 connection Ok building list... done items to clear: 149 warning: wrong packet cs items cleared: 149 of 149 building list... done items remains: 0 Finished, time used: 32 sec Remove/Install battery now ! ============================================= ver. sw 1: IACN26_07A_PMJ_PCB01_GPRS_MT6226M_S01.MAUI_07A_W07 _32_MP_V28.BIN ver. sw 2: MAUI.07A.W07.32.MP.V28, 00000000 ================================================== ======== COM8 [VCP0] selected module v2.69 Device: Spice-D88N Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: skip: skip: write: ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8B02:8B01]... CPU: MT6219 detected CPU: MT6226MA chip: 0031:B5C1:EA3E status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 04 ver. sw 1: IACN26_07A_PMJ_PCB01_GPRS_MT6226M_S01.MAUI_07A_W07 _32_MP_V28.BIN ver. sw 2: MAUI.07A.W07.32.MP.V28, 00000000 ffs offset/size: 00E00000/001F0000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[IACN26_07A_PMJ_PCB01_GPRS_MT6226M_S01.MAUI_07A_W07 _32_MP_V28.BIN]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[IACN26_07A_PMJ_PCB01_GPRS_MT6226M_S01.MAUI_07A_W07 _32_MP_V28.BIN]_20090430-035414.B0E.bin Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Area: flash: 98004900000002:2AEA0000000000 Area: flash: 98004900000002:2AEA0000000000 detect device identification#2... detection phase #1... . detect device identification#2 finished Write Done Finalization ... formatting... flash: 98004900000002:2AEA0000000000 Finalization Done Finished, time used: 1370 sec Remove/Install battery now ! SO, HOW TO REVIVE IT?? |
04-30-2009, 15:22 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, it is need to flash phone with other firmware (probably need to use newer firmware for new LCD type). What was with phone before flash ? Do you have original full flash backup ? |
05-01-2009, 09:29 | #3 (permalink) | |
Member: 411831 Status: Offline Thanks Meter: 215 | Quote:
and before it was restart sometimes,thatsway i flash it. | |
05-02-2009, 08:45 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, it will be good if somebody can read full flash from the same good working phone and send full flash backup to [email protected] so we will be able to prepare and upload good working files in support area for all users. |
05-02-2009, 16:07 | #6 (permalink) | |
thank you sir, i read full flash from same phone.but try to flash with that give error it say"data error" i will upload that file. thank you. | |
05-03-2009, 11:46 | #7 (permalink) | |
[email protected] and here http://www.mediafire.com/?sharekey=0...21d66e282a0ee8 | |
05-05-2009, 19:52 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @msantar Thanks for file ! We will prepare and upload it in support area ASAP. |
Infinity team plz help me and give me flash file | aamirgsm | Infinity-Box | 14 | 12-01-2008 08:41 |
infinity team plz help | ajmer | Infinity-Box | 2 | 10-14-2007 15:08 |
c140 cant unlock in infinity team plz help me | ramesh_931 | Infinity-Box | 7 | 07-20-2007 17:47 |
Infinity team plz help me to flash for nokia E60 | .::Munazzam::. | Infinity-Box | 7 | 06-27-2007 19:53 |
hi infinity team plz help ... | unlock_solution | Infinity-Box | 0 | 04-08-2007 20:01 |
