Old 02-13-2010, 08:36   #1 (permalink)
sheik9905677786's Avatar
Member: 1115989
Sonork: 9905677786
Thanks Meter: 3,202
Airtel fgd9000 unlocking
Dear Infinity Team I am confused That my cordless Airtel fgd9000 MODEL has been unlocked or not because i done it 2 method but with both of method i entered 2 different gsm sim in this model but in display show only emergency mode. so please help me.
here is first method details with eprom files
http://www.sendspace.com/file/l6t5m2
[2/13/2010 12:53:04 PM
Loading data, wait...
[Infinity Box] MModule v3.14
smart-card: connected
S/N: 1424:0112
Wait...
Done
Device: Airtel-Cordless-FGD8900
COM1 [VCP0] selected
module v3.14
Checking data, wait...
Action: "sp-unlock"
Warning ! After unlock process finished make this:
1. be sure that there is NO any SIM card in phone
2. press phone "Power" button and power-On phone
3. press phone "Power" button and power-Off phone
4. NOTE ! SIM card can be blocked during first power-On so use SIM card
that you ready to move to trash w/o problems !
5. now you can power-On phone with SIM card
Do you understand instruction and want to continue ?
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6205:8B00]...
CPU: MT6205
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC22A000000000:18E59F00000000
flash: Samsung AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb
otp offset: 003F0000
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
ffs/eeprom address can not be detected, value from database assigned: 00380000/00080000
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: Airtel-Cordless-FGD8900__ffs...
file saved: C:\Program Files\InfinityBox\MModule\Airtel-Cordless-FGD8900__ffs_20100213-125514.B0E.bin
Backup required data Done
====> Patch required data ...
detection procedure, wait...
detection procedure completed
Patch required data Done
====> Special operation ...
detecting parameters to apply patch area 1...
required data found
Write: area 1 (pass 1)
required data found
Write: area 1 (pass 2)
area 1 patch applied Ok
Special operation Done
====> Write ...
Write: ffs
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 2 min 8 sec
Remove/Install battery now !
Old 02-13-2010, 08:39   #2 (permalink)
Member: 1115989
Sonork: 9905677786
Thanks Meter: 3,202
and here is second method logs
module v3.14
Action: "sp-unlock"
unlock method: standard fast
Unlock procedure can be faster if you skip ffs/eeprom area backup procedure.
Do you want to disable ffs/eeprom backup ?
ffs/eeprom backup disabled
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6205
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
- damaged firmware
lock area found
lock area found
error: area 1 can not apply patch
====> Write ...
Write: lock-area-1
Write: lock-area-2
Write Done
Finalization Done
Finished, time used: 50 sec
so me waiting here your respone
Thanks!!!!
SHEIKH
Old 02-14-2010, 17:40   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
FGD9000 model is not the same as FGD8900. I sufggest you never make this kind of tests in future.
If you want to see FGD9000 supported - read full flash from FGD9000 with ChineseMiracle software and send full flash backup (or link) to [email protected]
Also, what is FGD9000 pinout ?
Old 02-15-2010, 07:41   #4 (permalink)
Member: 1115989
Sonork: 9905677786
Thanks Meter: 3,202
About FGD9000
Originally Posted by InfinitySupport View Post
Hello,
dear, Infinity Management You Ask About FGD9000 pinout.
So I Think Its C2500 Pinout Because When I Used C2500 Cable With This Model Its Connected.
And About Flah File Back I will Give You As Soon As Possible.
Thanks!!!!!!!!!!!!!!
SHEIKH
Old 02-15-2010, 08:33   #5 (permalink)
Member: 1115989
Sonork: 9905677786
Thanks Meter: 3,202
here is the flash file back up link=http://www.sendspace.com/file/is2rne
Old 02-15-2010, 13:59   #6 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hi,
file downloaded and checked.
What is exact phone model name (from phone back label) ?
Are you sure that it's FGD9000 model ?
Old 02-16-2010, 04:07   #7 (permalink)
Member: 1115989
Sonork: 9905677786
Thanks Meter: 3,202
boss how could u ask me like that kid question(sure) its my work that i doing my work with open eyes so for ur kind info its fgd9000 airtel (beetel) cordless phone.
Old 02-16-2010, 10:37   #8 (permalink)
Member: 1043909
why I ask:
FGD8900 firmware version : 05A.W05.24.43_8900.IN.AT.B.23.34_T8X00_HW_Jul-14-2006_En_Es_Pt
FGD9000 firmware version : 05A.W05.24.43_8900.IN.AT.B.23.54_T8X00_HW_Oct-16-2006_En_Es_Pt
as you can see it's hard to find difference in both.
anyway, now I am sure that your file is from FGD9000, I'll give you more information some time later
Old 02-16-2010, 15:06   #9 (permalink)
Member: 1115989
Sonork: 9905677786
Thanks Meter: 3,202
surprised
Originally Posted by YellowBoss View Post
why I ask:
boss i was also surprised about file version thats why i put here my question
by the way i still waiting .
Old 03-29-2010, 06:05   #10 (permalink)
Member: 1178113
Thanks Meter: 44
sir iwant un lock fgd 8900
Old 03-29-2010, 14:46   #11 (permalink)
Member: 1043909
Hello,
Just run Infinity-Box software, select required model, press "sp-unlock" button and follow the instruction given by software.
Old 02-20-2011, 10:41   #12 (permalink)
Member: 337100
Sonork: 100.1606722
Thanks Meter: 75
sir i have one set airtel fgd-8900 after unlock by infinity box....
after unlock it will be off when put sim card......
whats the problem i confused??????
Old 02-20-2011, 13:02   #13 (permalink)
Member: 1043909
Hi,
1. Are you sure that you follow unlock instruction exactly ?
2. try to make 112/emergency call without sim card.
What is the results ?
fgd 8900 airtel codless unlock zipzap_kill Infinity-Box 29 05-08-2013 12:47
24 Feb 2007: "Hero of India" in action: Airtel FGD8900 unlock... InfinitySupport Infinity-Box 23 05-23-2011 10:48
12/02/08 : ET-BoX v1.58 Released - Added Airtel FGD9000, ZTE A12 & Samsung C260m C266 .:ET-BoX.net:. ET-BoX 11 02-16-2008 06:33
c140 &s 404 airtel can't unlock. nirbhay Infinity-Box 1 08-10-2007 15:06
Page generated in 0.24759 seconds with 9 queries
