06-06-2018, 14:51 | #61 (permalink) | |
Product Manager Join Date: Mar 2014 Location: Bangladesh Age: 30
Member: 2142580 Status: Offline Thanks Meter: 1,214 | Quote:
you have any good modem file in 2017 & 2018 Latest security Downgrade Latest Security Downgrade is Risky in Baseband... | |
06-06-2018, 18:22 | #62 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Roumania
Member: 691388 Status: Offline Thanks Meter: 371 | Keep the same bit and it will be ok. For S8 g950xxu1crap u can use any modem from 7. For bit2 (g950xxu2....) can use only eng modem bit2 or u will get unknown baseband. Flashing back bit2 modem will get back imei. This is an exemple only. Use your mind for other models. Happy unlocking! |
06-11-2018, 17:45 | #63 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Torun, Poland Age: 40
Member: 25996 Status: Offline Thanks Meter: 253 | Are there any issues or dalays with this service today? I've added J330FN almost 4 hours ago and it's still marked as "executing" on website. Transaction id: 857836/1114210 |
06-11-2018, 18:03 | #64 (permalink) | |
No Life Poster Join Date: Mar 2002 Location: gsmcity Age: 45
Member: 10505 Status: Offline Sonork: 100.40828 Thanks Meter: 364 | Quote:
Open log file and check if BASE=SM-N900 all is OK, but if BASE=UNKNOW you will not receive codes from server. Fix it manually and resend log. Hope it will help. BR levsha | |
06-11-2018, 18:28 | #65 (permalink) | |
Member: 25996 Status: Offline Thanks Meter: 253 | I don't have access to that log file currently but i re-read it at home and i see: Quote:
06-12-2018, 08:52 | #66 (permalink) |
Member: 25996 Status: Offline Thanks Meter: 253 | Ok, so i verified the log file at work and this one has "BASE=UNKNOW". I fixed the log file but can't resend it as the same IMEI is marked as executing. I can't seem to find an info about this error anywhere in the first post. I would fix it all the way back if i knew about it. |
06-12-2018, 20:17 | #67 (permalink) |
Freak Poster Join Date: Mar 2007 Location: dz
Member: 463222 Status: Offline Thanks Meter: 29 | Hi All; Plz, why Exynos unlock tack more time (more than 7 hours) w/out code until now !? Date: 2018-06-12 10:40:54 Amount/Credits: -5 Credits From/To: System Product: Samsung Exynos unlock code Status: EXECUTING Tag: 35573009xxxxxxxx |
06-12-2018, 22:33 | #68 (permalink) |
Member: 25996 Status: Offline Thanks Meter: 253 | @youcgsm, this may be the same issue i'm having. Check the original log file for stuff @levsha posted as this seemed to be a problem in my case. Sadly, i can't re-send the log because it's already processing and i can't cancel it as well because support, both via PM here and directly on website does not respond for my tickets since yesterday... |
The Following User Says Thank You to KrzychuG For This Useful Post: |
06-12-2018, 23:29 | #69 (permalink) |
Member: 463222 Status: Offline Thanks Meter: 29 | I think its a system problem, as i check the log and All is ok cause i compared with an old log witch i got its code in less than 5 min. But this time i don't know what the prb.... |
06-13-2018, 12:28 | #72 (permalink) |
Product Supporter Join Date: Mar 2005 Location: in CPU
Member: 128745 Status: Offline Thanks Meter: 16,936 | hello we will refund ure credit . please use another service we are fixing the issue we need 2 days |
The Following User Says Thank You to Infinity-Box For This Useful Post: |
06-13-2018, 22:28 | #73 (permalink) |
Member: 25996 Status: Offline Thanks Meter: 253 | I'm willing to wait as i don't have that phone at hands anymore and customer is just waiting for code. It would be good to answer on any of the tickets just a bit earlier. I know that this service is relatively cheap, but still, this took a bit long to acknowledge that there is an issue. |
06-13-2018, 23:18 | #74 (permalink) | |
Member: 463222 Status: Offline Thanks Meter: 29 | Quote:
As i know of the Team is Always present and do the better....Thanks. | |
