08-31-2009, 12:13 | #1 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 892194 Status: Offline Thanks Meter: 12 | infinity team s319x problem help there see u have to flash the phone if u wantto unlok this phone right but when the process starts after loading the frimware when software comands u to press the power on i do press the power button but the phone is keep coming on when ever i press power button phones comes on instead of that flashing should start y its hapning what is this problem plz jhelp some 1 |
08-31-2009, 12:28 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Your_Home Age: 38
Member: 413053 Status: Offline Sonork: 100.114351 Thanks Meter: 458 | 1st check cabil must used Cable name: Alcatel-OT-C701 keyboard down connector 2x5 1 2 3 4 5 6 7 8 9 10 4: Box Tx/Phone Rx (RJ45 pin-2) and check infrinity com port ...... |
08-31-2009, 12:39 | #3 (permalink) |
08-31-2009, 12:42 | #4 (permalink) |
Member: 892194 Status: Offline Thanks Meter: 12 | whats is this keybord down means and second i dont have that cable i have so many other cables similar like that but what should i do now i use smtbox universal micro ns pro but this box is difrent u have any msn or hotmail id i dont have that cable i have some problemms with infinity |
08-31-2009, 22:45 | #5 (permalink) | |
You must use correct cable to make work well. Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
to infinity team fix problem R306 | ayhen42 | Infinity-Box | 1 | 01-17-2010 09:17 |
urgent help infinity team, strange problem | kimocyc | Infinity-Box | 2 | 12-25-2007 15:45 |
Mpeg4 k1 Infinity team need dire help | ziasim | Infinity-Box | 1 | 09-04-2007 12:58 |
INFINITY TEAM i need help please.. | togi | Infinity-Box | 3 | 06-18-2007 15:34 |
Infinity Team Can You Help Me Quick ?? | distefano | Infinity-Box | 2 | 11-04-2005 18:58 |
