12-01-2015, 10:39 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: P A K I S T A N
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | @infinity team SMART AV for MT6589 A750 SmartAV Report : Removed 33 infected files! Code: Wait for phone... Phone found! [ 19 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 484A019065324741A20102045780A508 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A4841473265040201A208A58057 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 33 Removing infected files and scripts ... SmartAV Report : Removed 33 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:03:05 Reconnect Power/Cable! Code: Operation : Remove Viruses [SmartAV] [ v1.37 ] SmartAV Conf : 100/75/4000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 484A019065324741A20102045780A508 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A4841473265040201A208A58057 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 16 Removing infected files and scripts ... SmartAV Report : Removed 16 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:00:49 Reconnect Power/Cable! Code: Chinese Miracle II [MTK module] v 1.37 Operation : Remove Viruses [SmartAV] [ v1.37 ] SmartAV Conf : 100/75/4000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 8 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 484A019065324741A20102045780A508 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A4841473265040201A208A58057 [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 16 Removing infected files and scripts ... SmartAV Report : Removed 16 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : PostFix Ok! Done! Done! Elapsed: 00:01:54 Reconnect Power/Cable! |
The Following User Says Thank You to gsmpointhrp For This Useful Post: |
12-01-2015, 10:55 | #2 (permalink) |
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | here is link this this infected file of MT6589 A750 i upload for infinity team coders maybe this can help you to investigate the problem https://mega.nz/#!iR5SFLhK!lcTcF5nV-...E1h5it-2D4neTw |
12-01-2015, 11:22 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. 1. Smart AV "IS NOT INTENDED TO CHECK RESULT"! It just remove viruses and make some kind of "permanent protection" from some of them after. That is main thing, which you should understand. 2. Result you can check only by run phone and check activity inside "Settings - Applications" Also, as @srinibas mentioned - you should make FactoryReset. Then run phone and check. |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
12-01-2015, 11:46 | #5 (permalink) | |
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | Yes brother i always do factory reset after SMART AV Quote:
12-01-2015, 11:47 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Just check result in settings - > applications. If there will be some malware - let me know. I can't download much due traffic limits, so, download it for nothing - will be time and traffic waste. |
12-01-2015, 12:17 | #8 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,073 | yes i am agree with gsmpointhrp as infinity team is best team in town and we need SMART AV feather more improved |
The Following User Says Thank You to kabul For This Useful Post: |
12-01-2015, 12:34 | #9 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | It already near it complete state. If check settings.ini and little play - result will be near 100% always. And again - check result possible ONLY via phone menu. SmartAV intended for make clean, not for check result. |
12-01-2015, 13:56 | #10 (permalink) |
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | i already check when we connect phone with wifi or sim data errors popup start again and again after that i notice SMART AV scan and clean result for this phone |
12-01-2015, 14:03 | #11 (permalink) |
Member: 416286 Status: Offline Sonork: 100.1622339 Thanks Meter: 759 | and my this test report is not for complaining but help to more improve of my favorite tool as i am satisfied from this tool |
12-01-2015, 16:53 | #12 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Heart of Asia
Member: 1706168 Status: Offline Sonork: 100.1619095 Thanks Meter: 66 | @JayDi Isn't it possible to add a feature to mount all apps and user can select which app to remove in Smart AV? Sorry if bad idea |
The Following User Says Thank You to m.aminhaqjoo For This Useful Post: |
