07-19-2008, 07:09 | #1 (permalink) |
Crazy Poster Join Date: Apr 2008
Member: 752130 Status: Offline Sonork: jibz Thanks Meter: 3 | infinity team still the same problem touch screen problem A8+ plz check here is my first tread..link /vbb/showthread...creen+infinity i already send the flash file to the support last week...... logs: COM12 [VCP2] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:EB41:77BC Connecting, wait... Release Power button now ! Phone detected, wait... warning: wrong packet cs Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: G60MTL_G60Mv01.01b05 Version: SIMC26_06B_HW detecting structure #2... 0warning: wrong packet cs done 44 byte(s) read imei: 35719801165791 connection Ok detecting structure #5... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15error: detection failed (16 tries) What to do: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 78 sec Remove/Install battery now ! there something wrong in the logs of formatting..."137 of 140 items cleared" "3 items remains" here is the logs.. COM12 [VCP2] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:EB41:77BC Connecting, wait... Release Power button now ! Phone detected, wait... warning: wrong packet cs Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: G60MTL_G60Mv01.01b05 Version: SIMC26_06B_HW detecting structure #2... 0warning: wrong packet cs done 44 byte(s) read imei: 35719801165791 connection Ok building list... done items to clear: 140 137 of 140 items cleared building list... done 3 items remains Finished, time used: 49 sec Remove/Install battery now ! thanks |
07-21-2008, 02:36 | #5 (permalink) |
Member: 752130 Status: Offline Sonork: jibz Thanks Meter: 3 | here is the other one n82 another touch screen problem i send the flash file in support on a privios days COM8 [VCP1] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:641C:65A5 Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: Z10.8LAN.V03.TCL Version: 06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 13579024681122 warning: current phone imei is wrong ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15error: detection failed (16 tries) What to do: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 69 sec Remove/Install battery now ! |
07-24-2008, 04:11 | #6 (permalink) | |
Member: 752130 Status: Offline Sonork: jibz Thanks Meter: 3 | where is the update Quote:
do i need return this two unit to the owner ?????? or i should wait 4 your update to fix this | |
07-24-2008, 21:28 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! No, do not return phones. Tomorrow will be released new version of Chinese Miracle it will recognise your A8+ software Sorry for delay |
07-27-2008, 05:23 | #10 (permalink) |
Member: 752130 Status: Offline Sonork: jibz Thanks Meter: 3 | thank you........for your work ..........its great........... my phone is 100% work..... here is the logs COM8 [VCP8] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:EB41:77BC Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: G60MTL_G60Mv01.01b05 Version: SIMC26_06B_HW detecting structure #2... 0warning: wrong packet cs done 44 byte(s) read imei: 35044801123456 connection Ok detecting structure #5 (mode-2)... done 160 byte(s) read writing data... verification... verification Ok Finished, time used: 18 sec Remove/Install battery now ! |
07-27-2008, 09:50 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
I reported this problem twice but still the same problem | netmos | Z3X-Team Products | 5 | 03-10-2010 10:30 |
infinity team touch screen problem A8+ help | jcjibz2 | Infinity-Box | 10 | 07-19-2008 23:17 |
Still the same problem with DCT4+ phones!!!!!! | Fones_Clinic_Network | Universalbox | 1 | 08-13-2007 23:37 |
still the same problem whis TST | CLIFFORD25502 | TST Dongle | 4 | 01-19-2006 08:15 |
