07-08-2008, 03:15 | #1 (permalink) |
Crazy Poster Join Date: Apr 2008
Member: 752130 Status: Offline Sonork: jibz Thanks Meter: 3 | infinity team touch screen problem A8+ help but after i format theres a problem the touch screen not work no rtesponse even tou touch the screen here is the log i alredy calibrate touch screen on the infinity but theres a error in the logs plzzz check........... here is the log: COM8 [VCP0] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:EB41:77BC Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: G60MTL_G60Mv01.01b05 Version: SIMC26_06B_HW detecting structure #2... 0 done 44 byte(s) read imei: 35719801165791 connection Ok detecting structure #5... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15error: detection failed (16 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 105 sec Remove/Install battery now ! |
07-08-2008, 07:54 | #4 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Quote:
How about to read text in software log window ? [email protected] | |
The Following User Says Thank You to InfinityN For This Useful Post: |
07-08-2008, 09:06 | #5 (permalink) |
Member: 752130 Status: Offline Sonork: jibz Thanks Meter: 3 | thanks 4 the rply i dont know how to send a flash file into infinity so i upload it to rapidshare here is the link....i need a solution badly my due date on this phone is tommorow.... action taken on the phone: read flash file fw. & eprom format write imei calibrate touch screen no luck...... firmware: http://rapidshare.com/files/12805736...8.B0M.bin.html eproom: http://rapidshare.com/files/12805981...4.B0E.bin.html |
07-08-2008, 09:59 | #6 (permalink) |
Member: 752130 Status: Offline Sonork: jibz Thanks Meter: 3 | the file was sent in the [email protected] thanks |
07-19-2008, 06:49 | #10 (permalink) |
Member: 752130 Status: Offline Sonork: jibz Thanks Meter: 3 | hi try the new update in the support chinese miracle v2.51 but still my problem not solve here is the logs: COM12 [VCP2] selected Action: touchscreen calibration Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:EB41:77BC Connecting, wait... Release Power button now ! Phone detected, wait... warning: wrong packet cs Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: G60MTL_G60Mv01.01b05 Version: SIMC26_06B_HW detecting structure #2... 0warning: wrong packet cs done 44 byte(s) read imei: 35719801165791 connection Ok detecting structure #5... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15error: detection failed (16 tries) What to do: 1. make full flash backup for emergency case 2. make "format ffs" 3. Power-On phone 4. Power-Off phone by "Power" button (do NOT remove battery) 5. Repeat "Calibration" operation again 6. if still no luck read full flash and send to support with subject: touchscreen calibration failed error: can't read required data error: operation failed ! Finished, time used: 78 sec Remove/Install battery now ! |
Curious: Touch screen is not working and is not touch screen problem | trentini | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 09-04-2009 16:23 |
Strange Touch screen problem - help please | jajukhan | iPhone 2 / iPhone 3G / iPhone 3GS | 11 | 04-21-2009 23:12 |
touch screen does not help, software problem? | kiubo | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 12-14-2008 18:59 |
infinity team still the same problem touch screen problem A8+ plz check | jcjibz2 | Infinity-Box | 10 | 07-27-2008 09:50 |
Help p910i touch screen problem | tahod | Sony Ericsson Hardware Repair | 2 | 10-17-2007 10:21 |
