04-03-2007, 18:57 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, see in support area or in "Documentation" folder after installation: "Test_Point_BenQ" BenQ-M300_M305_M315_O2X1i_O2X1B_testpoint1.jpg |
10-23-2008, 23:33 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, try this test point: I am not sure in success, need to try. Also, pls, check voltage at that pin before connect it to Gnd. It should be about +2.5v (when phone is powered-on). Also, if you can make a PCB photo for CPU side it will be good, but need to make good quality photo, much better than first time. |
10-23-2008, 23:51 | #8 (permalink) |
No Life Poster Join Date: Dec 2007 Location: FomTekLAB Mexico-United States
Member: 645603 Status: Offline Thanks Meter: 89 | realy work this TP..thanks here the log COM8 [VCP1] selected Device: BenQ M350 Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Connect test-point to Ground ! Press Power button now ! Connecting... Disconnect test-point ! Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Flash: 0089:885500010001 file saved: C:\Archivos de programa\InfinityBox\BModule\350\backup_eeprom-00_20081023-174606.3DF.bin Check Parameters Done Check Space... Flash: 0089:885500010001 flash: Intel 28F640W30-B B 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 0089:885500010001 Writing Done Finished, time used: 55 sec Remove/Install battery now ! THanks a lot.. |
