Infinity TEAM URGENT NEED HELP Hello Infinity Team, today i have facking a problem after Unlock Siemens CL75 Fone not get signal's ....... then i have try to sp-Unlock ======= COM1 selected Device: Siemens-CL75 Checking data, wait... Action: Unlock Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22202200:98E59F00000000 flash: Amd PL127J D 16Mb id: 0000527A Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... file saved: backup_eeprom_unlock-1_20071013-142848.21E.bin file saved: backup_eeprom_unlock-2_20071013-142848.21E.bin Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/03 Format file system Done Write... Preparing... area requested/selected: 02/03 Finalizing... area requested/selected: 02/03 Write Done Finished Remove/Install battery now ! Time used: 31 sec reset seting ========= COM1 selected Device: Siemens-CL75 Checking data, wait... advanced flash detection active Action: Reset Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22202200:98E59F00000000 flash: 01227E22202200:98E59F00000000 flash: Amd PL127J D 16Mb id: 0000527A Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/03 area-02... area requested/selected: 02/03 Format file system Done Write... Write Done Finished Remove/Install battery now ! Time used: 25 sec Read EROM ======== COM1 selected Device: Siemens-CL75 Checking data, wait... Action: Read Eeprom Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22202200:98E59F00000000 flash: Amd PL127J D 16Mb id: 0000527A Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... Reading [eeprom-calibration]... file saved: backup_eeprom-calibration_20071013-150030.21E.bin Reading [eeprom-fixed]... file saved: backup_eeprom-fixed_20071013-150031.21H.bin Finished Remove/Install battery now ! Time used: 21 sec Write EEPROm ========== COM1 selected Device: Siemens-CL75 Checking data, wait... advanced flash detection active Action: Flash write "smart write" enabled Skip: Firmware Skip: Map/Customization Skip: Language Pack Write: Eeprom Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22202200:98E59F00000000 flash: 01227E22202200:98E59F00000000 flash: Amd PL127J D 16Mb id: 0000527A Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... file saved: backup_eeprom_20071013-192418.21E.bin Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/03 area-02... area requested/selected: 02/03 Format file system Done Write... Write: Eeprom area requested/selected: 02/03 error: error: error: error: error: error: error: error: Write Done Finished Remove/Install battery now ! Time used: 50 sec But Now Fone Get Signal but Back Screen Gona OFF and FOne CENTER BUTTON MENU and DOWN click FOR check CONTECT LIST not Working On MAIN SCREEN if you go in setting Both working BUT on MAIN SCREEN not......:confused: |
make flash backup and try to flash phone with higher firmware version |
