09-29-2008, 12:51 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: IN mobile's
Member: 771565 Status: Offline Sonork: 100.1656305 Thanks Meter: 145 | infinity team what wrong Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:53C1:41D6 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: SUNPLUS25_06B_PCB01_GPRS_MT6225_S00.C5071C_V01_04_ IL_OV_071121_MSA.BIN ver. sw2: C5071C_V01.04_IL_OV_071121_MSA, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98004900000002:18E59F00000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 98004900000002:18E59F00000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 98004900000002:18E59F00000000 Finalization Done Finished, time used: 130 sec Remove/Install battery now ! phone still dead plz send solution as soon possible |
09-29-2008, 13:44 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If phone "still dead" this means that is was dead before "format" operation. Did you tried to make anything else with phone, f.e. flash it with good firmware or check it's hardware ? |
infinity team what is wrong with your box? | mvtamele | Infinity-Box | 2 | 04-07-2008 12:43 |
infinity team what is wrong? | mvtamele | Infinity-Box | 1 | 04-04-2008 13:15 |
GOT Team What Wrong ? | .:Morpheus:. | GOT SEMC | 1 | 03-08-2007 18:10 |
blazer team what wrong ? | celcom | Blazer | 9 | 04-13-2005 12:17 |
blazer team what wrong ? | celcom | Blazer | 0 | 04-09-2005 10:53 |
