12-13-2008, 07:46 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: Indonesia
Member: 368629 Status: Offline Thanks Meter: 87 | For Infinity Teams about Beyond B555 I'm the one of infinity Loyal *******r. i would hope in next update of Pana01 will be fully support Beyond B555. So far infinity already very great about this model. It's will be greater if Infinity can support flashing SST Flash Chip Algo. I tested in Pana01 V. 1.58 it's don't working for flashing but it support for simlock and user lock. this is the log when i flashing SST Flash Chip. ==== log: [13/12/2008 12:55:00] ==== COM8 [VCP2] selected module v1.58 Device: Beyond-B555 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... slowest Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... sw version: .00 ULC2GL f o 0 A p 0 q Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Beyond-B555_eeprom-static_20081213-125524.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Beyond-B555_eeprom-security_20081213-125525.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Beyond-B555_eeprom-complete_20081213-125531.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware error: erase failed: 00400000 Write Failed Finished, time used: 36 sec Remove/Install battery now ! 00BF-7353 IS THE CODE FOR SST FLASH CHIP DON'T TRY ANY OPERATIONS EXCEPT UNLOCK, OR ELSE IT WILL KILL YOUR PHONE (DOESN'T MATTER IF YOUR PHONE IS DEAD CONDITIONS BUT I GUARRANTY IT'S CAN'T BE REPAIRED UNLESS INFINITY TEAM FIX THIS ALGO) One thing i just want to make it straight this thread i made it for Suggestions only not Bossing the infinity team.... Sorry for my poor english. |
The Following User Says Thank You to torpedo_seluler For This Useful Post: |
12-13-2008, 15:54 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | To avoid heavy load and to avoid more red text message here is search results, please, everybody read it ! Result: select model BSNL G200CF and try to flash phone again. |
12-14-2008, 13:40 | #5 (permalink) | |
Any luck with flashing like BSNL G200CF ? | |
TO infinity team about china 1112 | /\/\A/\/| | Chinese Models & Cloned Phones | 4 | 02-02-2009 02:20 |
@ Infinity Team ABout Flashing J120i (URGENT) | bluffmaster | Infinity-Box | 3 | 09-19-2007 07:40 |
****suggestion For Infinity Team About Chinese Mirecle Flash Support****** | HAROON's | Infinity-Box | 3 | 08-29-2007 17:31 |
HELP ME Infinity TEAM ABOUT O2XLI FLASH FILE | shoag12345 | Infinity-Box | 2 | 08-16-2007 19:48 |
little question to infinity team about x400 flashing | chavrotti | Infinity-Box | 2 | 08-16-2005 12:36 |
