02-07-2010, 11:07 | #1 (permalink) |
No Life Poster Join Date: Aug 2009 Location: faisalabad PAKISTAN
Member: 1092450 Status: Offline Thanks Meter: 196 | infinity teem help me kg 195 after wole flash formet then phon dead then i make full flash then still phone is dead plz help me i useing this file 1,,KG195P64-ARB-V10d-000-00_DEC-10- 2007_ARIMA26_05C_PCB01_GPRS_MT6226_S01[1].7S7332SA00-001-R1C_En_Ru_Fr_Urdu_Farsi_Ar.B0M 2,,,KG195_repair_eeprom_01[1].B0E but phone is dead plz help me |
02-07-2010, 11:20 | #4 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Indonesia
Member: 69608 Status: Offline Thanks Meter: 63 | Flash using file from support.. then follow this from infinity document. How to fix LG KG195, KG200, KG300 freez/restart etc.: 1. Run "ChineseMiracle" software 2. Select model "MT6228 NAND" 3. Make "format" by "whole flash chip" method 4. repair imei |
02-07-2010, 11:20 | #5 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | 1st of all , without log how can we say any thing ? logs is just our eyes so post log then we will tell you what to do Br Faisal_Computer |
02-07-2010, 11:33 | #8 (permalink) |
Member: 1092450 Status: Offline Thanks Meter: 196 | sir i sey phone hang lg logo then very slow prosasing and key pad light is blenking this time i make complet formet ffs COM4 [VCP0] selected module v3.03 Device: LG-KG195 Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 chip: 0031:CB41:B33C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001-R1C.BIN project-id: 7S7332SA00-001-R1C, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: LG-KG195_ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001-R1C__ffs... file saved: C:\Program Files\InfinityBox\MModule\LG-KG195_ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001-R1C__ffs_20100207-022802.B0E.bin flash: 98004900000002:29EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98004900000002:29EA0000000000 Finalization Done Finished, time used: 7 min 28 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
02-07-2010, 11:33 | #10 (permalink) | |
Freak Poster Join Date: Feb 2007 Location: @ MY SOUL
Member: 450542 Status: Offline Sonork: 100.1590626 Thanks Meter: 61 | here is log Quote:
COM4 [VCP0] selected module v3.09 Device: LG-KP320 Checking data, wait... Action: write flash NAND write: Firmware KP320-00-V10i-404-XX-JUL-01-2008_A7610_07A_PCB03_GPRS_MT6229_S02[1].7S7610IN00-001-R2R_En_Hi.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610IN00-001-R2R.bin nfi area detection finished: Ok interface: BROM_DLL_v3.932.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6229:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: S_DA_NOR_FLASH_NOT_FOUND warning: NOR flash chip is not installed NAND flash chip: S_DONE flash id[0014]: 0098:00F100900095 [TOSHIBA] TC58NVG0S3AFT flash size: 128Mb page/spare size: 0800/0040 pages/block: 0040 bits i/o: 08 address cycles: 04 internal RAM: S_DONE size: 00020000 external RAM: S_DA_DEVICE_NOT_FOUND done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610IN00-001-R2R.bin nfi area detection finished: Ok startup code area #1 check... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... error: can not write flash: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND Disconnect... done Finished, time used: 2 min 41 sec Remove/Install battery now ! | |
02-07-2010, 11:34 | #11 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | flash phone with firmware from support area. If phone still can not power-on well you must open phone and check it's hardware. if you do not trust me you must read this example: http://forum.gsmhosting.com/vbb/showthread.php?t=915195 |
02-07-2010, 11:35 | #12 (permalink) |
Member: 1092450 Status: Offline Thanks Meter: 196 | yes you chack this file it,s ok and i am right 1,,KG195P64-ARB-V10d-000-00_DEC-10- 2007_ARIMA26_05C_PCB01_GPRS_MT6226_S01[1].7S7332SA00-001-R1C_En_Ru_Fr_Urdu_Farsi_Ar.B0M 2,,,KG195_repair_eeprom_01[1].B0E but phone is dead plz help me |
02-07-2010, 11:37 | #14 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,421 | @ mobiletuch where is log when you did whole format ? it should take backup. write that backup and post results and if one flash file not works for your mobile then try another flash file from support and post results Br Faisal_Computer |
help charge kg 195 | zie_dab | LG Hardware Repair | 11 | 03-17-2010 12:58 |
infinity box teem help me kg 270 | mobiletuch | Infinity-Box | 4 | 03-03-2010 16:42 |
kg 195 after formet wole flash phone is dead plz help me | mobiletuch | LG Hardware Repair | 2 | 02-16-2010 17:16 |
Kg 195 after one hour battery low | sadafsdkSADAFSD | LG Hardware Repair | 1 | 04-08-2009 09:03 |
infinity teem help me | rajtelecom | Infinity-Box | 6 | 10-23-2007 11:24 |
