01-08-2017, 14:18 | #1 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Infinity Test Version SM software for Samsung You can download from support area newly released software for Samsung devices. Click here to download Infinity Dongle must be connected to PC to use this software ! You can test this software, see how is it works and post here your suggestions for future research and development. Please always post operation logs so we will be able to see result. ==== New information 23 Jul 2017 === To use software v1.00 and higher please login to your IOS account and activate for your Dongle Infinity Samsung software activation for FREE ! Last edited by InfinityHelp; 07-23-2017 at 12:15. |
The Following 52 Users Say Thank You to InfinitySupport For This Useful Post: |
01-08-2017, 14:23 | #2 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Samsung s3 csc flashing with cm2 SAMSUNG S3 CSC FLASHING WITH CM2 Phone found on COM345 Port open Ok! LOKE received! Prepare Ok! Enter Setup... Setup Done! Try download PIT... Download PIT Ok! Start flashing! Flashing cache.img Flashing hidden.img Reboot phone... Phone Disconnected Please add unlocking and imei repair service Last edited by rahihimkhan; 01-08-2017 at 14:31. |
The Following 6 Users Say Thank You to rahihimkhan For This Useful Post: |
01-08-2017, 14:37 | #3 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Great Move Good News For User's Need One More Great Move In jtag Field Infinity-Team Is Very Old And Trusted Team We All Wel-come On This Move |
The Following 11 Users Say Thank You to Deepesh Sharma For This Useful Post: |
01-08-2017, 15:09 | #6 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
Csc - Write Done! | |
The Following 5 Users Say Thank You to pradeep_kus For This Useful Post: |
01-08-2017, 15:44 | #9 (permalink) |
No Life Poster Join Date: Nov 2015 Location: DHAKA
Member: 2489690 Status: Offline Thanks Meter: 289 | great work infinity team you have done it again and again please add frp in next update |
The Following 2 Users Say Thank You to chadzar For This Useful Post: |
01-08-2017, 15:53 | #10 (permalink) |
No Life Poster Join Date: May 2006 Location: Omer Mobile Shopee Age: 41
Member: 272979 Status: Offline Sonork: 100.1607215 Thanks Meter: 135 | After the Testing is over should we need to purchase a separate activation ????? |
The Following User Says Thank You to feel_free For This Useful Post: |
01-08-2017, 16:19 | #11 (permalink) |
Major Poster Join Date: Mar 2008 Location: india jaipur 919829218536
Member: 715814 Status: Offline Sonork: 100.1662740 Thanks Meter: 2 | mi 2013029 not suppoted Card found : 73F4D438 , v0134 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.08 Operation : Read PatternLock [ v1.08 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 060B22BF ID_BLOCK_I : 009150E1 ID_BLOCK_L : C43C56A00F9B80837CD1232CEBB63E0E ID_BLOCK_L : C6BD03AAAF36982DA00F40B98B7A7457 Use CM2 Internal Loader Error : Prepare target failed! Unsupported yet CPU! Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Reset UserLocks [ v1.08 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Error : Fail to init protocol! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.08 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 060B22BF ID_BLOCK_I : 009150E1 ID_BLOCK_L : C43C56A00F9B80837CD1232CEBB63E0E ID_BLOCK_L : C6BD03AAAF36982DA00F40B98B7A7457 Use CM2 Internal Loader Error : Prepare target failed! Unsupported yet CPU! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
01-08-2017, 16:58 | #15 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | I8262 Reset pattern Done. Code: Phone found on COM27 Port open Ok! LOKE received! Prepare Ok! Enter Setup... Setup Done! Try download PIT... Download PIT Ok! Start flashing! Flashing cache.img.ext4 Flashing hidden.img.ext4 Reboot phone... Phone Disconnected Phone found on COM25 Phone Disconnected |
The Following 2 Users Say Thank You to mbiborna For This Useful Post: |
