j100h remove virus done by flash only system.img Code: Phone found on COM22 aپ 1X uZ ’A |
old phone flashing problem s5360 android 2.3 after flash with infinity reboot to recovery only after flash with odin done Code: Flashing boot.img |
in release note it say it have some imei repair features, how did i repair imei ? |
Hi sir, for Flashing beside Odin i mostly use chimera tool. I have almost all files downloaded by Chimera. If its possible Please add support chimera files also axcepted by infinity samsung tool. Thanks Br, Raja |
Hi sir, SM-G3608 flash good and with good speed. Card found! Main Infinity-Box/Dongle S/N: 003EA4381E Phone found on COM6 Port open Ok! LOKE received! Prepare Ok! Enter Setup... Setup Done! Try download PIT... Download PIT Ok! Start flashing! Flashing aboot.mbn Flashing sbl1.mbn Flashing rpm.mbn Flashing tz.mbn Flashing hyp.mbn Flashing NON-HLOS.bin Flashing sec.dat Flashing boot.img Flashing recovery.img Flashing system.img.ext4 Flashing cache.img.ext4 Flashing hidden.img.ext4 Flashing modem.bin Flashing done Reboot phone... Phone Disconnected Thanks Br, Raja |
s7582 flash done Code:
Hi Sir, I have noted problem after flash SM-C9000 with latest firmware. With HOME and without HOME file. After Flash it goes to recovery and says DMV failed. Card found! Main Infinity-Box/Dongle S/N: 003EA4381E Phone found on COM4 ( ? Port open Ok! LOKE received! Prepare Ok! Enter Setup... Setup Done! Try download PIT... Download PIT Ok! Start flashing! Flashing aboot.mbn Flashing sbl1.mbn Flashing rpm.mbn Flashing tz.mbn Flashing devcfg.mbn Flashing NON-HLOS.bin Flashing cmnlib.mbn Flashing keymaster.mbn Flashing apdp.mbn Flashing msadp.mbn Flashing sec.dat Flashing lksecapp.mbn Flashing boot.img Flashing recovery.img Flashing system.img.ext4 Flashing persist.img.ext4 Flashing modem.bin Flashing adspso.bin Flashing cache.img.ext4 Flashing cache.img.ext4 Flashing meta-data/ Partishion not found Phone Disconnected Phone found on COM4 öM ÀPort open Ok! LOKE received! Prepare Ok! Enter Setup... Setup Done! Try download PIT... Download PIT Ok! Start flashing! Flashing aboot.mbn Flashing sbl1.mbn Flashing rpm.mbn Flashing tz.mbn Flashing devcfg.mbn Flashing NON-HLOS.bin Flashing cmnlib.mbn Flashing keymaster.mbn Flashing apdp.mbn Flashing msadp.mbn Flashing sec.dat Flashing lksecapp.mbn Flashing boot.img Flashing recovery.img Flashing system.img.ext4 Flashing persist.img.ext4 Flashing modem.bin Flashing adspso.bin Flashing cache.img.ext4 Flashing done Reboot phone... Phone Disconnected Phone found on COM4 But when i flash with odin its ok. <ID:0/004> Added!! <ID:0/004> Odin engine v(ID:3.1205).. <ID:0/004> File analysis.. <ID:0/004> SetupConnection.. <ID:0/004> Initialzation.. <ID:0/004> Set PIT file.. <ID:0/004> DO NOT TURN OFF TARGET!! <ID:0/004> Get PIT for mapping.. <ID:0/004> Firmware update start.. <ID:0/004> SingleDownload. <ID:0/004> aboot.mbn <ID:0/004> sbl1.mbn <ID:0/004> rpm.mbn <ID:0/004> tz.mbn <ID:0/004> devcfg.mbn <ID:0/004> NON-HLOS.bin <ID:0/004> cmnlib.mbn <ID:0/004> keymaster.mbn <ID:0/004> apdp.mbn <ID:0/004> msadp.mbn <ID:0/004> sec.dat <ID:0/004> lksecapp.mbn <ID:0/004> boot.img <ID:0/004> recovery.img <ID:0/004> system.img.ext4 <ID:0/004> persist.img.ext4 <ID:0/004> modem.bin <ID:0/004> Transmission Complete.. <ID:0/004> Now Writing.. Please wait about 2 minutes <ID:0/004> Receive Response from boot-loader <ID:0/004> adspso.bin <ID:0/004> Transmission Complete.. <ID:0/004> Now Writing.. Please wait about 2 minutes <ID:0/004> Receive Response from boot-loader <ID:0/004> cache.img.ext4 <ID:0/004> RQT_CLOSE !! <ID:0/004> RES OK !! <ID:0/004> Removed!! And DMV also goes OK. Please if its fault in SM remove it or IF i am wrong then need help. Thanks Br, Raja |
Infinity Team, When is the Full version CM2 Samsung Module coming out?? We've being waiting for the Full version for a long Time now...Please, inform us. |
CM means Chinese Miracle. I can not understand why Samsung is Chinese Miracle. Samsung is Korean Miracle but not Chinese. |
Thanks for the correction, but when is the Full Infinity Box Samsung Module coming OUT? |
