06-21-2007, 14:05 | #1 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | Problem unlocking after flash Motorola C 140 PHONE LOCKED it show me Current model: C139,C140 Loading file v.02... C139_1[1].3.28_Main_1152683132.31M.bin Loaded Loading file v.02... C139_1[1].3.28_LPL_LATAM_Z1B_En_Es_Pt.31P.bin Loaded Loading file v.02... C139_1[1].3.28_Flex_FFL_3W_X1B_704-01.31F.bin Loaded COM1 selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 1.0.32 HW version: _E88 LP ver: LPE_C139_EMEA_T17_01F Flex ver: FFE_C139_63_11F imei otp: 353020015832935 Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_353020015832935_20070621-123843.31E.bin imei eeprom: 353020015832935 Check Flash-2 Done Write... Writing: Firmware Writing: Language Pack Writing: Flex Write Done Finished, time used: 344 sec Remove/Install battery now ! COM1 selected Action: unlock Device: C139,C140 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 error: boot failure[07]: version mismatch, other connection settings should be used. Release Power button ! |
06-21-2007, 17:16 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | See FAQ thread: http:///vbb/showthread.php?t=342807 you will see the answer in 2nd message. |
06-23-2007, 09:57 | #3 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 579 | i can t unlock wth all methods my version phone 001A1020 644271975595 who:Sw-cm Wed Jul 12 13:45:32 2006 Sw:Ver 1.3.28 FFL_C139_3W_X1B LPL_C139_LATAM_Z1B |
06-23-2007, 10:17 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | What is th problem with unlock ? Just for info: it's really good idea to explain the problem but not only say "oh... nothig works". also, if this phone cant be unlocked just flash it with more old 1.x.x firmware. |
After flash motorola w220 show no service | RIYANA TELECOM | Infinity-Box | 7 | 10-01-2009 12:46 |
i900 problem unlock after flashing | dbarakov | NSPRO | 1 | 04-01-2009 09:41 |
Motorola L6 Cant Unlock After Flashing | toptech | Ultima Box Light | 6 | 06-04-2008 14:14 |
Problem Mars-After Flash | saveli | Mitsubishi | 36 | 06-07-2001 08:42 |
