04-23-2008, 11:11 | #1 (permalink) |
Freak Poster Join Date: Nov 2003 Age: 50
Member: 44531 Status: Offline Thanks Meter: 5 | Infinity unlock Vodafone 226 COM1 [Serial0] selected Device: Vodafone 226 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported sw version: EBI_IH 280607_1821 EBI_IH_280607_1821 Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Vodafone 226_eeprom-sta_20080423-051456.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Vodafone 226_eeprom-sec_20080423-051500.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Vodafone 226_eeprom-complete_20080423-051505.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 2 already done (mode-0), operation aborted Check memory Failed Finished, Remove/Install battery now ! Time used: 47 sec help me |
04-23-2008, 11:20 | #2 (permalink) |
Member: 44531 Status: Offline Thanks Meter: 5 | COM1 [Serial0] selected Device: Vodafone 226 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported sw version: EBI_IH 280607_1821 EBI_IH_280607_1821 Thhmm Dddmmmyyyy 01234567 Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Vodafone 226_eeprom-sta_20080423-052002.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Vodafone 226_eeprom-sec_20080423-052005.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_Vodafone 226_eeprom-complete_20080423-052010.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 61 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 But wrong code 2 mins later you may retry code 00000000 ok |
04-25-2008, 18:09 | #5 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Holland China Brazil Age: 43
Member: 88016 Status: Offline Thanks Meter: 320 | I tried to unlock it with infinity , so i got 12345678, and when i enter codes,got message (codes are wrong) Finally i unlocked it with sagemdd for free. BR Kashif Khan |
04-27-2008, 13:29 | #6 (permalink) |
Registered User Join Date: Feb 2006 Location: Pakistan Age: 46
Member: 238519 Status: Offline Sonork: 100.1589249 Thanks Meter: 21 | Hi.. I dont find the pinouts of vodafone 226 in shell.. plz u check this.. its show blank then select vodafone 226. thanks in advance. Kamijeeawan |
04-27-2008, 15:23 | #7 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
05-06-2008, 15:10 | #8 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: india
Member: 239231 Status: Offline Sonork: 100.1615723 Thanks Meter: 110 | Quote:
hi can u explain me how to unlock vodaphone 226 with sagemdd box plz explain in full thx in advance REGARDS MAIMOON MOBILES | |
05-13-2008, 08:53 | #10 (permalink) |
No Life Poster Join Date: Jun 2001 Location: www.microera.si
Member: 4923 Status: Offline Thanks Meter: 74 | I make this cable: http://forum./show...79&postcount=7 and download Pana01 v1.46 but I get: COM1 [Serial0] selected Device: Vodafone 226 Checking data, wait... Action: read eeprom Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... error: can't run preloader: 01 middle part... error: can't run middle loader: AA01 Finished, Remove/Install battery now ! Time used: 8 sec or COM1 [Serial0] selected Device: Vodafone 226 Checking data, wait... Action: read eeprom Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... middle part... error: can't run middle loader: 01 Finished, Remove/Install battery now ! Time used: 6 sec any HELP? |
need help from infinity to unlock vodafone 226 | sartaj | Infinity-Box | 2 | 02-22-2008 09:32 |
need help for unlock vodafone 226 | hanen | Infinity-Box | 3 | 02-12-2008 15:18 |
can SMTi unlock Vodafone 226 soon? | ktele | SMTi | 1 | 12-21-2007 10:15 |
CID 52/53 Unlock VERY CHEAP ! Motorola by IMEI (fast) Sagem w8 Unlock, Vodafone 226 | allGSMUnlock | Main Sales Section | 0 | 11-02-2007 17:59 |
