Infinity virgin needs help Ok I've got this far; Quote:
Any ideas ? :o Thanks in advance... BR :) |
Remove everything and do a clean install again, but this time only install Infinity_DRV.exe, than plug your USB dongle, not the box!!! When searching for new hard ware point it to Program Files\InfinityBox\Drivers\e-gate_W2k_XP\ After that run SNreader.exe. and Enjoy. The Beast |
Hello, Pls, check in Device Manager: these 3 devices have to be present. 1. e-gate Virtual Reader Enumerators -> e-gate Virtual Reader Enumerator 2. Smart card readers -> e-gate USB Smart card reader 3. e-gate USB Smart Cards -> e-gate USB Smart Card Also, install SN-Reader installer again, restart PC and try to run SN-Reader.exe again. B.R. InfinitySupport |
Hi InfinitySupport, Thanks for the support so far. Ok I have ; 1. e-gate Virtual Reader Enumerators -> e-gate Virtual Reader Enumerator 2. Smart card readers -> e-gate USB Smart card reader But not ; 3. e-gate USB Smart Cards -> e-gate USB Smart Card http://tinypic.com/96w0vk.jpg Should I do as The Beast suggested, as that usually works with unlocking boxes ? BR :) Quote:
Hi, Yes, you can try this advice. But first: Do you see Dongle LED blinking when you insert/remove dongle into/from USB ? B.R. InfinitySupport |
Hi, Yep, it blinks about 3/4 times green as I insert it into the USB port :) . But is it ment to blink when I remove it ? Because it doesn't but the PC makes the usual noise, so the dongle seems ok to me. :) BR Quote:
Hi, It's good, dongle Ok. Pls, try to make as The Beast suggested. B.R. InfinitySupport |
Just unlock my first X70 ;) Thanks Infinity team :) |
hi for me install as instructed but i do NOT see any of the below in my System Device.( Xp sp2) 1. e-gate Virtual Reader Enumerators -> e-gate Virtual Reader Enumerator 2. Smart card readers -> e-gate USB Smart card reader 3. e-gate USB Smart Cards -> e-gate USB Smart Card my donlge is ok. cuz its works on another pc. what can i do br ktv |
Try to reinstall donele driver , and install again |
i have lost count of how many times i try to uninstall/reinstall and still can't not see those devices. Unfortunatly the other pc ****n-up , and very desparatly to get this working... is there any tricks to this.. br ktv |
Hi , It seems some software is conflicting with our device driver in ure PC , It is a very stranege problem , can u ask help from ure reseller ? if he is in the same city can u take ure CPU to him ? may be he can install it correct for you ? Regards Kashan |
my resaler is too far away. got it from narrygsm.com he is in China and i'm in Australia thankx for respond. hope that you have solution for me soon br ktv |
Hi, Do you see dongle LED blinking when you insert dongle into PC ? Are you sure that you can't see all 3 (three) devices: 1. e-gate Virtual Reader Enumerators -> e-gate Virtual Reader Enumerator 2. Smart card readers -> e-gate USB Smart card reader 3. e-gate USB Smart Cards -> e-gate USB Smart Card |
dongle LED does NOT blink when i plug-in dongle , in Device Manager more Devices detected BUT the three(3) mentioned. ONLY THIS 1. ports(com & PLT ) - USB serial port(com 20) 2. Universal serial bus controller -generic usb hub -usb serial converter br ktv |
