Old 07-20-2005, 18:11   #1 (permalink)
Patrick's Avatar
Member: 100436
Red face Infinity virgin needs help
Ok I've got this far;
4.2. Driver installation (W2K/XP)
1. Run: Infinity_Drv.exe
After this installation part will be completed, make the next steps:
2. Run: Program Files\InfinityBox\Drivers\e-gate_W2k_XP\Setup.exe
3. Insert Box dongle into USB port
Your system now have three new devices:
1. e-gate Virtual Reader Enumerators -> e-gate Virtual Reader Enumerator
2. Smart card readers -> e-gate USB Smart card reader
3. e-gate USB Smart Cards -> e-gate USB Smart Card
4. Insert Cable and select drivers from folder: Program Files\InfinityBox\Drivers\Cable
4.3. Serial Number reader installation
1. Run: Infinity_SNReader.exe
2. Reboot PC
3. Insert dongle and run SNReader.exe:you will get UserName and Passord for support area access at http://www.infinity-box.com
I can't get the SNReader to read my box, I get this http://tinypic.com/96kfox.jpg !
Any ideas ?
Thanks in advance...
The Following User Says Thank You to Patrick For This Useful Post:
Old 07-20-2005, 19:14   #2 (permalink)
Member: 61620
Remove everything and do a clean install again, but this time only install Infinity_DRV.exe, than plug your USB dongle, not the box!!! When searching for new hard ware point it to Program Files\InfinityBox\Drivers\e-gate_W2k_XP\
After that run SNreader.exe. and Enjoy.
The Beast
Old 07-20-2005, 19:16   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
Hello,
Pls, check in Device Manager: these 3 devices have to be present.
Also, install SN-Reader installer again, restart PC and try to run SN-Reader.exe again.
B.R.
InfinitySupport
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 07-20-2005, 21:25   #4 (permalink)
Patrick's Avatar
Member: 100436
Hi InfinitySupport,
Thanks for the support so far.
Ok I have ;
But not ;
http://tinypic.com/96w0vk.jpg
Should I do as The Beast suggested, as that usually works with unlocking boxes ?
Originally Posted by InfinitySupport
Hello,
B.R.
InfinitySupport
Old 07-20-2005, 21:30   #5 (permalink)
Member: 130995
Hi,
Yes, you can try this advice.
But first:
Do you see Dongle LED blinking when you insert/remove dongle into/from USB ?
B.R.
InfinitySupport
Old 07-20-2005, 21:42   #6 (permalink)
Patrick's Avatar
Member: 100436
Hi,
Yep, it blinks about 3/4 times green as I insert it into the USB port .
But is it ment to blink when I remove it ? Because it doesn't but the PC makes the usual noise, so the dongle seems ok to me.
Hi,
But first:
B.R.
InfinitySupport
Old 07-20-2005, 21:48   #7 (permalink)
Member: 130995
Hi,
It's good, dongle Ok.
Pls, try to make as The Beast suggested.
B.R.
InfinitySupport
Old 07-21-2005, 01:16   #8 (permalink)
Patrick's Avatar
Member: 100436
Checking data, wait...
Device have to be SWITCHED OFF
Press Power button now...
TestMode Ok
Set Baud...
Set Baud Done
Parameters...
SW Version: GAX70A3232040408
FLASH-ID: 89000D88
Parameters Done
Check data...
STEP-02 in progress...
Check data Done
Check HW...
FLASH supported[89000D88]
Check HW Done
Operation...
Working, don't interrupt...
Action-1 Ok
Action-2 Ok
Action-3 Ok
FLASH-ID: 89000D88
Action-4 Ok
Action-5 Ok
Action-6 Ok
STEP-2 complete !
Operation Done
Process completed
Phone Unlocked Ok !
Remove/Install battery now !
Finished
Wahooooooo
Just unlock my first X70
Thanks Infinity team
Old 11-12-2005, 01:51   #9 (permalink)
Member: 14607
hi
for me install as instructed but i do NOT see any of the below in my System Device.( Xp sp2)
my donlge is ok. cuz its works on another pc.
what can i do
br
ktv
Old 11-12-2005, 07:37   #10 (permalink)
Member: 128745
Try to reinstall donele driver , and install again
Old 11-13-2005, 02:38   #11 (permalink)
Member: 14607
i have lost count of how many times i try to uninstall/reinstall and still can't not see those devices. Unfortunatly the other pc ****n-up , and very desparatly to get this working...
is there any tricks to this..
br ktv
Old 11-13-2005, 07:38   #12 (permalink)
Member: 128745
Hi ,
It seems some software is conflicting with our device driver in ure PC ,
It is a very stranege problem , can u ask help from ure reseller ?
if he is in the same city can u take ure CPU to him ? may be he can install it correct for you ?
Regards
Kashan
Old 11-13-2005, 22:31   #13 (permalink)
Member: 14607
my resaler is too far away.
got it from narrygsm.com he is in China and i'm in Australia
thankx for respond. hope that you have solution for me soon
br
ktv
Old 11-14-2005, 04:02   #14 (permalink)
Member: 130995
Hi,
Do you see dongle LED blinking when you insert dongle into PC ?
Are you sure that you can't see all 3 (three) devices:
Old 11-14-2005, 04:53   #15 (permalink)
Member: 14607
dongle LED does NOT blink
when i plug-in dongle , in Device Manager more Devices detected BUT the three(3) mentioned.
ONLY THIS
1. ports(com & PLT )
- USB serial port(com 20)
2. Universal serial bus controller
-generic usb hub
-usb serial converter
br
ktv
Hi INFINITY TEAM, Need Help with DB2020 PASSIONATE_BOYS Infinity-Box 8 06-28-2008 08:24
hello infinity i need help david laborator Chinese Miracle & PinFinder 8 02-06-2008 02:56
hello infinity i need help david laborator Chinese Miracle & PinFinder 1 09-12-2007 09:15
dear Infinity team need help saeed-gsm Chinese Miracle & PinFinder 2 07-12-2007 10:52
C139 and infinity problem need help berigaz ODM (Original Design Manufacturing) 2 06-29-2006 22:39
Page generated in 0.57211 seconds with 11 queries
