Old 03-10-2011, 05:59   #1 (permalink)
gsmkhmer's Avatar
Member: 1218675
Thanks Meter: 24
Huawei G6620 unlock success
I use method read code as i show in the picture below but it's not success.
See more detail log:
COM3 [VCP0] selected
module v3.79
Action: read unlock codes
unlock method: read codes
Model: Huawei-G6620
Checking data, wait...
19200 autodetect
Initializing [6253:8A02:8A00]...
CPU: MT6253
chip: 0000:0000:000F
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6253,E02
Date: 2000.00.00
Version: 1.0
Version: G6620SD.C206.M40.08.02
Version: CKT53_12832_09B_HW
New firmware found (v.3.79, database date: 07.03.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
116 byte(s) read
imei: 35194804254583
connection Ok
217 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
205 byte(s) read
reading data...
220 byte(s) read
lock[1] code: + 39507030
lock[2] code: + default
lock[3] code: + 1122
lock[4] code: - default
lock[5] code: - default
lock[6] code: + default
lock[7] code: + default
if code is not accepted by phone:
- make full flash backup for emergency case
- flash phone with good eeprom file
- Power-On phone without sim-card
- Power-Off phone
- read unlock codes
- restore original imei
Finished, time used: 1 min 44 sec
Remove/Install battery now !
Here is it full flash that i read and more detail about phone:
Huawei-G6620_SJ_S0A_HW_BEELINE_PCB01_GPRS_MT6253_S00.G662 0SD_C206_M40_08_02.BIN_FLNTY6801111190KC__fullflas h_20110310-105643.B0M.zip - 4shared.com - online file sharing and storage - download
Old 03-10-2011, 06:24   #2 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
- Power-Off phone
- read unlock codes
r u try this ?????????????
Old 03-10-2011, 06:25   #3 (permalink)
Cheater -Don't Deal with him-
Member: 265129
Thanks Meter: 281
Please Infinity Team Add Flashing This Phone because i have one dead in hand.
Old 03-10-2011, 06:54   #4 (permalink)
gsmkhmer's Avatar
Member: 1218675
Thanks Meter: 24
How to enter code to phone?
thanks.....
Old 03-10-2011, 07:45   #5 (permalink)
Member: 1320228
how to instal softwer for HUAWEI E1550
Old 03-10-2011, 08:19   #6 (permalink)
adilosse's Avatar
Member: 568259
Thanks Meter: 52
module v3.79
Model: Huawei-G6620
19200 autodetect
CPU: MT6253
status: FF
Date: 2000.00.00
Version: 1.0
116 byte(s) read
connection Ok
217 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
205 byte(s) read
reading data...
220 byte(s) read
- Power-Off phone
- read unlock codes
hi did you mean that the code calculated by infinity is not correct?
in this case try this:
1. insert any sim card into phone
2. power-on phone with sim card (enter pin-code if need)
3. power-off phone by "Power" button (do not remove battery)
4. try to read unlock codes and post results here
if codes still can not be read well make the same, but enter one wrong unlock code after step 2.
Try to read codes again.
Let's see results.
Old 03-10-2011, 11:54   #7 (permalink)
Member: 130995
Thanks Meter: 35,227
@gsmkhmer
you have an unlock code that was read by our software.
Did you tried to enter this code into phone ?
Old 03-10-2011, 11:57   #8 (permalink)
Member: 130995
thanks.....
Just power-on phone with wrong sim card and phone ask you to enter code.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 03-11-2011, 05:12   #9 (permalink)
gsmkhmer's Avatar
Member: 1218675
Thanks Meter: 24
Originally Posted by InfinitySupport View Post
@gsmkhmer
Sorry sir, i didn't try to enter code to phone yet.
i confuse that just read code the software will unlock directly, that's my fault.
and i'm so sorry cuz the owner take it back.
Old 03-26-2011, 08:22   #10 (permalink)
Member: 165303
Sonork: 100.1580123
Thanks Meter: 57
unlock don
COM18 [VCP0] selected
module v3.80
Model: Huawei-G6620
19200 autodetect
CPU: MT6253
status: FF
Date: 2000.00.00
Version: 1.0
Version: G6620SS.C200.M40.04.10
New firmware found (v.3.80, database date: 20.03.2011):
116 byte(s) read
imei: 35194804291280
connection Ok
217 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
205 byte(s) read
reading data...
220 byte(s) read
lock[1] code: + 37732842
if phone do not ask for a code try: *983*8284#
- Power-Off phone (do not remove battery)
- read unlock codes
Finished, time used: 18 sec
The Following User Says Thank You to nvad For This Useful Post:
Old 08-21-2011, 17:33   #11 (permalink)
Burnt Cobba's Avatar
Member: 11325
Thanks Meter: 266
Mine unlocked after following the procedure of entering 12345678, powering it off and then retry to read the codes again. Worked 100% OK Phone is from T-Mobile UK. Sent flash to support.
Thanks Infinity team for your great tools and support!
Here is log 1st log :-
COM15 [VCP0] selected
module v4.01
Model: Huawei-G6620
19200 autodetect
CPU: MT6253
high speed boot On
status: FF
Date: 2000.00.00
Version: 1.0
Version: G6620SS.C200.M40.04.13N
New firmware found (v.4.01, database date: 19.08.2011):
- send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage
116 byte(s) read
imei: 35194804958101
connection Ok
217 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
205 byte(s) read
reading data...
220 byte(s) read
lock[1] code: + default
- insert wrong sim card into phone
- power-On phone
- enter code: 12345678
- wait 10 seconds
- power-Off phone via "Power" button (do not remove battery)
- read unlock codes again
Finished, time used: 14 sec
Here is 2nd log:-
module v4.01
Model: Huawei-G6620
19200 autodetect
CPU: MT6253
high speed boot On
status: FF
Date: 2000.00.00
Version: 1.0
116 byte(s) read
connection Ok
217 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
205 byte(s) read
reading data...
220 byte(s) read
lock[1] code: + 39279755
- read unlock codes
Finished, time used: 15 sec
The Following User Says Thank You to Burnt Cobba For This Useful Post:
Old 08-23-2011, 18:00   #12 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 792
unlocked ok thank you.
COM7 [VCP0] selected
module v4.01
Model: Huawei-G6620
19200 autodetect
CPU: MT6253
high speed boot On
status: FF
Date: 2000.00.00
Version: 1.0
116 byte(s) read
imei: 35194804987181
connection Ok
217 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
205 byte(s) read
reading data...
220 byte(s) read
lock[1] code: + 36047716
- read unlock codes
Finished, time used: 16 sec
Old 09-13-2011, 21:27   #13 (permalink)
Member: 975300
Sonork: 100.1593908
Thanks Meter: 21
COM393 [VCP0] selected
module v4.01
Model: Huawei-G6620
19200 autodetect
CPU: MT6253
high speed boot On
status: FF
Date: 2000.00.00
Version: 1.0
Version: G6620SS.C210.M40.04.05
116 byte(s) read
imei: 3519xxxxxxxxxx
connection Ok
217 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
205 byte(s) read
reading data...
220 byte(s) read
lock[1] code: + 35833516
- read unlock codes
Finished, time used: 20 sec
my huawei g6620 unlocked successefully
Old 09-14-2011, 21:08   #14 (permalink)
Member: 130995
module v4.01
Model: Huawei-G6620
19200 autodetect
CPU: MT6253
high speed boot On
status: FF
Date: 2000.00.00
Version: 1.0
116 byte(s) read
connection Ok
217 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1234
205 byte(s) read
reading data...
220 byte(s) read
- read unlock codes
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
Old 09-19-2011, 19:40   #15 (permalink)
Member: 1087723
Sonork: albo_gangsta
is it free to do this?
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:06
Page generated in 0.29106 seconds with 9 queries
