09-06-2015, 14:54 | #1 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2213738 Status: Offline Sonork: 100 Thanks Meter: 8 | InfinityBox CM2MTK.exe cannot run. all the others are opening well ; ie InfinityBox CM2SPD, CM2RDA BEST support said post here . please help |
09-12-2015, 16:43 | #6 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2406517 Status: Offline Sonork: 100.1641481 Thanks Meter: 38 | Q mobile x70 format done Wait for phone... Phone found! [ 5 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4838473264040501A29778222D DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d2G8 [eMMC] : FLASH_CID : 90014A4838473264040501A29778222D [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Backup : Skipped by user request FMT Mode set to : 0 Format : UserData Only (Factory Reset) Format UDA block Format block Ok! Done! BR GSM BOSS |
The Following 3 Users Say Thank You to hamza gsm boss For This Useful Post: |
03-06-2017, 16:28 | #8 (permalink) |
Freak Poster Join Date: Oct 2004 Age: 46
Member: 88864 Status: Offline Thanks Meter: 10 | i have same problem only with cm2qlm soft.all others run fine reinstall or delete fault.bin doesnt help |
The Following User Says Thank You to gedasgsm For This Useful Post: |
03-07-2017, 23:32 | #11 (permalink) | |
