Old 03-16-2017, 13:45   #1 (permalink)
Member: 1456426
Sonork: 100.1625000
Thanks Meter: 104
m95 hung on logo
hung on logo flash but same i erase now show this logs Card found: S/N : DCF7726A , v0135
Chinese Miracle II [SPD module] v 1.24
Operation : Format File System / Reset Settings [ v1.24 ]
Settings : SmartFormat is On
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 21 ]
Open Port Failed!
Reconnect Power/Cable!
Operation : Check/Read Info [ v1.24 ]
3. Insert cable
Phone found! [ 21 ]
Open Port Failed!
3. Insert cable
Phone found! [ 21 ]
Open Port Failed!
3. Insert cable
Phone found! [ 21 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v3 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
Detected eMMC Flash , Structure detect Ok!
eMMC phone detected! Will use 'Safe Format' mode!
UserData : PART_MOUNT failed! Part Damaged! Will use Repair Mode!
Cache : PART_MOUNT failed! Part Damaged! Will use Repair Mode!
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Done!
Elapsed: 00:00:18
Operation : Flash Erase [ v1.24 ]
3. Insert cable
Phone found! [ 21 ]
Open Port Failed!
3. Insert cable
Phone found! [ 21 ]
Open Port Failed!
3. Insert cable
Phone found! [ 21 ]
Open Port Failed!
3. Insert cable
Phone found! [ 21 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Erasig flash now, please wait ...
Format finished! Reflash phone with normal FW now!
Elapsed: 00:00:46
3. Insert cable
Phone found! [ 21 ]
Open Port Failed!
3. Insert cable
Phone found! [ 21 ]
Open Port Failed!
3. Insert cable
Phone found! [ 21 ]
Open Port Failed!
3. Insert cable
Phone found! [ 21 ]
Open Port Failed!
3. Insert cable
Phone found! [ 21 ]
Open Port Failed!
3. Insert cable
Phone found! [ 21 ]
Open Port Failed!
3. Insert cable
Phone found! [ 21 ]
Open Port Failed!
3. Insert cable
Phone found! [ 21 ]
Open Port Failed!
3. Insert cable
Phone found! [ 21 ]
Open Port Failed!
3. Insert cable
Phone found! [ 21 ]
Open Port Failed!
3. Insert cable
Phone found! [ 21 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Unknown structure detected! Check correct model selection!
Elapsed: 00:00:11
Infinity SC Firmware Detected
FW Size : 1239 MiB
Load Ok!
Operation : Flash [ v1.24 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
3. Insert cable
Phone found! [ 21 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC773x Android 5.x eMMC v1.0 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
[FL] : Enabled NVM update. Will program all NVM images found in FW !
PMTManager : Load 0x17 records
PMTManager : PMT Update Failed!!!
Selected firmware doesn't match to current HW or EMPTY battery!
Flashing terminated!
Elapsed: 00:00:07
======= Flash
3. Insert cable
Phone found! [ 21 ]
Open Port Failed!
======= Flash
3. Insert cable
Phone found! [ 21 ]
Open Port Failed!
======= Flash
3. Insert cable
Phone found! [ 21 ]
Open Port Failed!
======= Flash
3. Insert cable
Phone found! [ 21 ]
Open Port Failed!
======= Flash
3. Insert cable
Phone found! [ 21 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Elapsed: 00:00:00
3. Insert cable
Phone found! [ 21 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Elapsed: 00:00:24
3. Insert cable
Phone found! [ 21 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
DS : Loader start failed! Wrong Model selection!
Boot failed!
Page generated in 0.13274 seconds with 8 queries
