01-29-2018, 11:13 | #1 (permalink) |
Major Poster Join Date: Mar 2016
Member: 2546186 Status: Offline Thanks Meter: 3 | InfinityBox CM2QLM not detecting any device i've tried so many devices but it could not detect any one of them i've installed the InfinityBox_update_CM2QLM_Drivers_v1.00 but nothing has changed i've used EDL cable and nothing happen i've reinstalled the application and no result any new suggestions plz Code: Card found : * , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! |
01-29-2018, 11:29 | #2 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Hello, Download latest drivers here http://dl1.infinity-box.com/download...ivers_v1.01.7z if still have problem watch here http://forum.gsmhosting.com/vbb/12184991-post1.html |
The Following 2 Users Say Thank You to Kirumira For This Useful Post: |
01-29-2018, 11:29 | #3 (permalink) | |
Freak Poster Join Date: Apr 2016 Location: Daska Punjab
Member: 2564979 Status: Offline Sonork: khalidartist Thanks Meter: 22 | Quote:
The Following 2 Users Say Thank You to khalidmughal007 For This Useful Post: |
01-29-2018, 12:14 | #4 (permalink) | |
Member: 2546186 Status: Offline Thanks Meter: 3 | Quote:
sir i can't find Care Suite Emergency Connectivity driver i have only these drivers EmergencyDownloadDriver Qualcomm_Diag WinUsbCoInstallers WinUsbCompatIdInstaller WinUsbDriversExt | |
01-29-2018, 12:26 | #5 (permalink) | |
No Life Poster Join Date: Mar 2012 Location: India
Member: 1728736 Status: Offline Sonork: 100.1615042 Thanks Meter: 1,098 | Quote:
The Following User Says Thank You to .:Sanjh Phoenix:. For This Useful Post: |
