05-06-2017, 09:32 | #1 (permalink) |
Crazy Poster Join Date: Dec 2016 Age: 36
Member: 2661439 Status: Offline Thanks Meter: 16 | InfinityBox CM2QLM please support new cpu Operation : Reset Settings [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 610 [MSM8936] ID_BLOCK_S : 06B630E9 ID_BLOCK_I : 0090B0E1 ID_BLOCK_E : 0039005A ID_BLOCK_L : 49D3B440CED60E3035E7800C53E2E078 ID_BLOCK_L : 9ECAEA1C64D5C80F6F498E7BB0459A0A Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! https://forum.gsmhosting.com/vbb/****************************/?o3sql8eloadgz16 |
05-06-2017, 09:55 | #2 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Miracle Box Is BEST
Member: 1158378 Status: Offline Thanks Meter: 23 | Card found : xxxxxxxxxx , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.11 Operation : Read Flash [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 610 [MSM8936] ID_BLOCK_S : 04381B2D ID_BLOCK_I : 0090B0E1 ID_BLOCK_E : 00040000 ID_BLOCK_L : 9CA190F3AE3847EDD960E31CB692EBB7 ID_BLOCK_L : 7C14CC4195B8451AA855D6BDC5563E2D Use CM2 Internal Loader Loader Sent! Initializing ... Error : FH Configuration failed! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! lyf Ls 5503 |
05-06-2017, 22:13 | #3 (permalink) | |
Remove battery, cable. Check cable and connection. Repeat operation! | |
05-15-2017, 16:39 | #4 (permalink) | |
Member: 2661439 Status: Offline Thanks Meter: 16 | Quote:
please support new cpu | |
